[Qgis-user] WMS-T printing issue
Giovanni Manghi
giovanni.manghi at gmail.com
Mon Oct 10 14:29:00 PDT 2011
Hi Freddy,
many standard WMS servers do not allow to download images bigger than a
certain size, this is the reason why there are usually no problems to
create a large size layout on screen (because it is at 72dpi) but then
it results in a blank image when printing or exporting to pdf (at high
resolutions).
Since qgis 1.7 when connecting to a WMS server you can manually set the
maximum "tile" size to be requested. This allow to overcome the server
limits.
http://www.youtube.com/faunalia#p/a/u/1/0phOQD3wTAU
This option is not available (as it does not makes sense) when the
server is recognized as a tilecache one (the layers are shown in the
"tilesets" tab).
Cheers
-- Giovanni --
On Mon, 2011-10-10 at 13:40 +0200, Frederick Löbig wrote:
> Hi list,
> I have a major problem creating ISO-A0 size plots with QuantumGIS and
> a Tileset-layer.
> When I add the layer to the project with the ?tiled=true attribute,
> the navigation within the map-window is nice and fast and the look is
> really good. When I create plot-template and use an external pdf
> creator (CutePDF writer) it only works good for formats smaller or
> equal than ISO-A2. Any plot of a bigger format results in an empty
> plot (at least the raster-layer isn't plotted, all added vector
> elements such as legend, northing, border etc. is plotted). I had a
> look at geoservers log to check for any errors resulting from
> insufficient memory or else with no result. Everything seems to have
> worked fine according to the log file.
> Has anyone had this kind of problem as well or does anybody have a
> workaround for that?
> Best,
> Freddy
> B.Eng. Frederick Löbig
> Röderichstraße 59
> 60489 Frankfurt am Main
> E:: Frederick.Loebig at grunsnid.de
> P: +49 (0) 69 - 78 99 52 41
> M: +49 (0) 174 - 70 89 296
> Office:
> euNetworks GmbH
> Ludwig-Landmann-Straße 405
> 60486 Frankfurt am Main
> P: +49 (0) 69 - 90 554 - 534
> E: Frederick.Loebig at eunetworks.com
> S: floebig
> This email and any attachments may contain confidential and/or legally
> privileged information. If you are not the intended recipient, please
> delete the email without reading it and notify the sender.
> Qgis-user mailing list
