[Qgis-user] QGIS 1.6 project causing 1.7 to crash
Nathan Woodrow
madmanwoo at gmail.com
Tue Oct 11 06:20:08 PDT 2011
Can you search the xml in the project file for VectorBackgroundMapMarch2011
and post each line it is mentioned on. The only time QGIS will throw the
Data Source is invaild error is in the ogr provider and somehow it is trying
to load your project as a layer which it then bombs on.
- Nathan
On Tue, Oct 11, 2011 at 11:10 PM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
> Very strange indeed.
> - Nathan
> On Tue, Oct 11, 2011 at 10:59 PM, Purves Ross <rmpurves at ntlworld.com>wrote:
>> OK, thanks for the tip re file number! Fingers crossed it's not that
>> though.
>> Sorry - now I get you. You mean can I load the layer called
>> 'VectorBackgroundMapMarch2011' in its own right into a fresh project, right?
>> Here's the rub - and also why I was confused by your question - there's no
>> apparent layer with that name in the project! That's the name of the overall
>> .qgs file, not a layer within it. Seems strange?
>> Many thanks!
>> Ross
>> On 11 October 2011 13:53, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>> I recall hearing about a bug where layers fail to load if there is a
>>> certain number of files in the project but this might be something
>>> unrelated.
>>> I mean can you load /mnt/bunker/ross/Research/PhD/NewMapMarch2011/VectorBackgroundMapMarch2011
>>> in QGIS on it's own in a fresh project.
>>> - Nathan
>>> On Tue, Oct 11, 2011 at 10:51 PM, Purves Ross <rmpurves at ntlworld.com>wrote:
>>>> Hi Nathan,
>>>> OK - by counting the number of occurances of '<maplayer' in the project
>>>> file, I count 50 layers. Sounds a lot but there were no problems in 1.6 with
>>>> this number!
>>>> Sorry to be stupid, not sure what you mean by load the file by itself.
>>>> Are you saying that there is a way of selectively loading layers on opening
>>>> a QGIS project file? Or do you mean opening the file in a text editor or
>>>> something. If the latter, then it certainly loads the XML OK and there's no
>>>> evidence that the file is corrupted.
>>>> Thanks again for the help!
>>>> Cheers
>>>> Ross
>>>> On 11 October 2011 13:44, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>>>> How many layers do you have in this project file? And can you load the
>>>>> file by itself?
>>>>> - Nathan
>>>>> On Tue, Oct 11, 2011 at 10:35 PM, Ross Purves <RMP at lutonsfc.ac.uk>wrote:
>>>>>> Hi Nathan,
>>>>>> Very many thanks for the quick response! OK, running from the command
>>>>>> line gives me slight more info, to be sure:
>>>>>> [Tue Oct 11 13:34:26 RMPT43:NewMapMarch2011 ]$ qgis
>>>>>> Warning: loading of qgis translation failed
>>>>>> [/usr/share/qgis/i18n//qgis_en_GB]
>>>>>> Warning: loading of qt translation failed
>>>>>> [/usr/share/qt4/translations/qt_en_GB]
>>>>>> Warning: Couldn't load Python support library: Cannot load library
>>>>>> /usr/lib/qgispython: (/usr/lib/libqgispython.so: cannot open shared object
>>>>>> file: No such file or directory)
>>>>>> Critical: Data source is invalid
>>>>>> Critical:
>>>>>> Additionally, when I start QGIS this way I get a pop up window within
>>>>>> the graphical interface that says:
>>>>>> The layer
>>>>>> is not a valid layer and can not be added to the map
>>>>>> The strange thing is that I'm pretty certain there is no problem with
>>>>>> the project file. It's timestamp reads 22 April, when I last worked on it.
>>>>>> I.e. the version of QGIS has changed but my file has remained constant.
>>>>>> Many thanks!
>>>>>> Ross
>>>>>> ________________________________________
>>>>>> From: Nathan Woodrow [madmanwoo at gmail.com]
>>>>>> Sent: 11 October 2011 13:26
>>>>>> To: Purves Ross
>>>>>> Cc: qgis-user at lists.osgeo.org
>>>>>> Subject: Re: [Qgis-user] QGIS 1.6 project causing 1.7 to crash
>>>>>> Hi Ross,
>>>>>> That sounds a bit strange. Can you start QGIS from the terminal and
>>>>>> see what the output is when it locks up.
>>>>>> - Nathan
>>>>>> On Tue, Oct 11, 2011 at 10:19 PM, Purves Ross <rmpurves at ntlworld.com
>>>>>> <mailto:rmpurves at ntlworld.com>> wrote:
>>>>>> Hi there,
>>>>>> I've updated my Ubuntu 10.10 installation to use QGIS 1.7. I put a lot
>>>>>> of work into a project using QGIS 1.6 but it won't open in 1.7. The layers
>>>>>> all appear but then the screen freezes as though QGIS is rendering the
>>>>>> resulting map forever.
>>>>>> A bit of googling revealed that there was a bug at some point which
>>>>>> required the placement of 'gdal' between all <provider></provider> tags in
>>>>>> the project XML file in a scenario like this. However, I tried this and it
>>>>>> didn't work. I also have read various posts that say the use of 'on the fly'
>>>>>> project appeared to cause problems going between 1.6 and 1.7. The project in
>>>>>> question does indeed use on the fly projection.
>>>>>> As a final note, I have an ECW raster layer in this map that requires
>>>>>> the modified GDAL to work. I thought that the crash might be to do with the
>>>>>> upgrade having removed my modified version of GDAL. I therefore recompiled
>>>>>> it all and have checked to see that my version of 1.7 can now read ECW files
>>>>>> and it can (when they are presented a a fresh layer and not as part of the
>>>>>> problematic project).
>>>>>> This is a really, really important project to me and I do need to get
>>>>>> it back if at all possible. Please can anyone help?
>>>>>> Very many thanks!
>>>>>> Ross Purves
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111011/e7d316bf/attachment.html>
