[Qgis-user] use ESRI file geodatabase format in QGIS + gdal 1.9
    Even Rouault
    even.rouault at mines-paris.org
    Wed Oct 12 12:45:38 PDT 2011
Le mercredi 12 octobre 2011 21:38:20, karsten a écrit :
> Hi,
> I was wondering if the ESRI file geodatabase format now can be used with
> QGIS because gdal/ogr 1.9 apparently contains that driver ..?
> So the question is whether I would e able use a file geodatabase in a (if
> needed custom built ) QGIS when I would have a gdal 1.9 compiled with file
> geodatabase support on my system or would there need to be additional
> changes to the QGIS itself needed to enable this ?
No change required in QGIS. It's abstracted by OGR API. It works already
provided that you build GDAL against the FileGDB SDK and link QGIS against
this GDAL build.
> Cheers Karsten
> Karsten Vennemann
> Principal
> Terra GIS LTD
> 2119 Boyer Ave E
> Seattle, WA  98112
> USA
> www.terragis.net <http://www.terragis.net/>
> Email scanned by PC Tools - No viruses or spyware found.
> (Email Guard: 7.0.0.27, Virus/Spyware Database: 6.18500)
> http://www.pctools.com/
