[Qgis-user] how to identify individual points on a map
Ramon AndiƱach
custard at westnet.com.au
Tue Oct 18 18:27:51 PDT 2011
I'm also confused. It reads to me that the lat/longs are in the data file already.
If that's the case, wouldn't the Identify Features Tool do what you need?
(By default this only shows information from the currently selected layer, but this can be changed in Settings->Options->Map Tools)
-ramon.
On 19/10/2011, at 3:04, Giovanni Manghi <giovanni.manghi at gmail.com> wrote:
> Hi,
> I'm not sure I understood your question, if not try the "point sampling
> tool" plugin.
> Cheers
> -- Giovanni --
> On Tue, 2011-10-18 at 11:51 +0100, M.E.Dodd wrote:
>> There are some plugins that will sort of do this but not found
>> something that allows easy click on a point to immediately see all the
>> information about that point, then click on another one to see info
>> about that point. An example, a map with thousands of points(each
>> with a code number and lat long info) plotted over a google basemap
>> layer, just zooming in on the points shows the google location in its
>> coordinate system not the lat long info that could be used to find the
>> location in the points .csv file.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111019/657acc4d/attachment.html>
