[Qgis-user] changing the default behavior for "coordinate reference system of new layers" in QGIS general options?
jonathanmoules at warwickshire.gov.uk
Mon Oct 24 03:50:32 PDT 2011
+1, though my own take is that the coordinate system should default to the
first loaded layer (ala ArcGIS), though an option somewhere to specify
default behaviour would be good, just so long as the current behaviour
changes.
Jonathan
To: qgis-user <qgis-user at lists.osgeo.org>
Date: 19/10/2011 22:18
Subject: Re: [Qgis-user] changing the default behavior for
Sent by: qgis-user-bounces at lists.osgeo.org
On 19/10/2011, at 23:36, "Dennis M. Linton" <dennis at dmlinton.net> wrote:
On Wed, 2011-10-19 at 16:33 +0200, Micha Silver wrote:
On 10/19/2011 04:20 PM, Ricardo Filipe Soares Garcia da wrote:
Giovanni Manghi <giovanni.manghi at gmail.com> wrote:
Hi all,
I would like to know your opinion about the above question.
My point of view, after giving many training courses, is that the
default option should be changed to "prompt for CRS", eventually
adding a checkbox in the dialog windows that pops up, to avoid being
asked over and over for the reminder of the session.
+1 from me as well
It is usually the first setting that I change whenever I install QGIS
on a new machine.
I also think this is the right approach. I don't like programs hiding the
gritty details, rather, user's should be confronted with the question,
forcing them to understand a bit better...
+1 for me too.
As an engineer without particular GIS expertise but for whom QGIS provides
a very useful resource, being forced into correct procedures is definitely
a good idea. I have spent more than my share of time trying to figure
out, and correct, things like Ontario, Canada being displayed in two
places at once or all of the roads in Ontario being displayed encompassed
by Moira Lake.
+1 here too. Once I found this setting, it's something that gets changed
on every install that I do.
-ramon. _______________________________________________
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111024/dd32911c/attachment.html>
