[Qgis-user] problems with georeferencing results
G. Allegri
giohappy at gmail.com
Tue Oct 25 15:42:43 PDT 2011
Ok, i got it.
The reason it doesn't work is probably easily explained: the source X/Y are
considered as raster space coordinates, while I thought that having the
raster a CRS assigned this was kept into account during the warping.
Probably manual re-georeferencing is conceptually unuseful, outside my
exercise. Even if reprojection wasn't enough, the best way would be to
remove any CRS reference from it.
Tomorrow I will do more tests, but I'm pretty sure that I was simply trying
a wrong procedure...
giovanni
2011/10/26 G. Allegri <giohappy at gmail.com>
> Sure Baren, this was just an exercise ;)
> I wanted to test regeoreferencing a raster and compare manual
> georeferencing against reprojection.
> I'm wondering if manually regeoreferencing an already georeferenced raster
> can break things...
> Inviato da dispositivo mobile
> Il giorno 25/ott/2011 22.43, "Barend Köbben" <kobben at itc.nl> ha scritto:
> Hi Giovanni,
>> I don't understand: you want to change a projected raster (in CRS 3003) to
>> another projection (23023), so why do you need the georeferencing plugin?
>> The data is already referenced, so it sounds to me you just want to
>> re-project it, using the Raster > Warp menu.
>> Or am I missing something...?
>> Yours,
>> Barend Köbben (Senior Lecturer)
>> ITC - University of Twente, Faculty of Geo-Information
>> Science and Earth Observation
>> PO Box 217, 7500AE Enschede (The Netherlands)
>> +31-(0)53 4874 253
>> On 25-10-11 21:23, "G. Allegri" <giohappy at gmail.com> wrote:
>> >Thanks for the reply.My raster infos are:
>> >PROJCS["Monte Mario / Italy zone 1",
>> > GEOGCS["Monte Mario",
>> > DATUM["Monte_Mario",
>> > SPHEROID["International 1924",6378388,297.0000000000014,
>> > AUTHORITY["EPSG","7022"]],
>> > AUTHORITY["EPSG","6265"]],
>> > PRIMEM["Greenwich",0],
>> > UNIT["degree",0.0174532925199433],
>> > AUTHORITY["EPSG","4265"]],
>> > PROJECTION["Transverse_Mercator"],
>> > PARAMETER["latitude_of_origin",0],
>> > PARAMETER["central_meridian",9],
>> > PARAMETER["scale_factor",0.9996],
>> > PARAMETER["false_easting",1500000],
>> > PARAMETER["false_northing",0],
>> > UNIT["metre",1,
>> > AUTHORITY["EPSG","9001"]],
>> > AUTHORITY["EPSG","3003"]]
>> >Origin = (1554747.231034494200000,4924790.769999999600000)
>> >Pixel Size = (100.000000000000000,-100.000000000000000)
>> >Metadata:
>> > AREA_OR_POINT=Area
>> >Image Structure Metadata:
>> > INTERLEAVE=BAND
>> >Corner Coordinates:
>> >Upper Left ( 1554747.231, 4924790.770) ( 9d41'17.95"E, 44d28'24.73"N)
>> >Lower Left ( 1554747.231, 4678290.770) ( 9d39'49.22"E, 42d15'14.92"N)
>> >Upper Right ( 1771747.231, 4924790.770) ( 12d24'49.32"E, 44d25'28.44"N)
>> >Lower Right ( 1771747.231, 4678290.770) ( 12d17'30.22"E, 42d12'31.70"N)
>> >Center ( 1663247.231, 4801540.770) ( 11d 0'50.84"E, 43d20'53.55"N)
>> >Band 1 Block=2170x1 Type=Float32, ColorInterp=Gray
>> > Min=-3.876 Max=2051.503
>> > Minimum=-3.876, Maximum=2051.503, Mean=152.789, StdDev=265.873
>> > NoData Value=0
>> > Metadata:
>> > STATISTICS_MINIMUM=-3.8761155605316
>> > STATISTICS_MAXIMUM=2051.5034179688
>> > STATISTICS_MEAN=152.78946158147
>> > STATISTICS_STDDEV=265.87340110007
>> >As you can see the CRS is correctly defined, and the other metadata are
>> >correct.
>> >OTFR works fine, the raster is correctly reprojected on the 23032
>> >reference.
>> >No tfw or aux files in the same folder....
>> >It's making me crazy!
>> >giovanni
>> >2011/10/25 Richard Duivenvoorde <rdmailings at duif.net>
>> >On 2011-10-25 19:04, G. Allegri wrote:
>> >> Here it is the GCP list picture: http://bit.ly/suh5UL
>> >> (I wonder why ths srcY coordinates are shown as negative values)
>> >What is projection of your raster, is it really epsg:3003 (to be tested
>> >with 'gdalinfo yourraster'.)
>> >Is there maybe a tfw file hanging around which determines another extent
>> >four your source raster? If seen this behaviour recently while using the
>> >plugin.
>> >Try to set your tiff aside from other files, create a fresh epsg:23032
>> >project with 'on the fly' and try again?
>> >Hope this helps.
>> >Regards,
>> Faculty of Geo-Information Science and Earth Observation (ITC)
>> Chamber of Commerce: 501305360000
>> E-mail disclaimer
>> The information in this e-mail, including any attachments, is intended for
>> the addressee only. If you are not the intended recipient, you are hereby
>> notified that any disclosure, copying, distribution or action in relation to
>> the content of this information is strictly prohibited. If you have received
>> this e-mail by mistake, please delete the message and any attachment and
>> inform the sender by return e-mail. ITC accepts no liability for any error
>> or omission in the message content or for damage of any kind that may arise
>> as a result of e-mail transmission.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20111026/311ef1df/attachment.html>
