[Qgis-user] Mac portable drive
Elvin Birth
elvin.birth at gmail.com
Fri Apr 6 14:32:33 PDT 2012
" QGIS Tip 9 *L**OAD LAYER AND PROJECT FROM MOUNTED EXTERNAL DRIVES ON **OS
X*
*On OS X, portable drives that are mounted besides the primary hard drive
do not show up under File Open*
*Project as expected. We are working on a more OSX-native open/save dialog
to fix this. As a workaround*
*you can type ’/Volumes’ in the File name box and press return. Then you
can navigate to external drives and*
*network mounts."*
*My copy of the manual has this tip on page 38. *
*I put an QGIS alias in the portable drive and open from there. All the
files including Project are readily available.*
*Hope this helps someone, Elvin Birth *
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120406/6df18b64/attachment.html>
