[Qgis-user] Re: building QGIS with GRASS 7.0
Paulo van Breugel p.vanbreugel at gmail.com
Sat Apr 7 01:15:17 PDT 2012
Ok, I did overlook something obvious, re-compiling the gdal-grass
plugin. However, when running configure I get the following error message:
configure: error: --with-grass=/usr/local/grass7/grass-7.0.sv requested,
but libraries not found!  Perhaps you need to set LD_LIBRARY_PATH to
include /usr/local/grass7/grass-7.0.sv/lib?
I did add a file 'grass7.conf' into the directory /etc/ld.so.conf.d/
with the path to the GRASS libraries. I also ran 'ldconfig'.
This all works when compiling the plugin for GRASS 6.4 so I am not sure
what I am doing wrong. Any ideas?
On 04/07/2012 12:38 AM, Paulo van Breugel wrote:
> Hi,
> I try to compile QGIS_master with GRASS 7.0 support (on Ubuntu 11.10).
> In the ccmake file, I use:
> GRASS_PREFIX: /usr/local/grass7/grass-7.0.svn/
> GRASS_INCLUDE_DIR: /usr/local/grass7/grass-7.0.svn/include
> LIB_PATH: /usr/local/grass7/grass-7.0.svn/lib/libgrass_gproj.so
> However, running configure, it does not find the LIB_PATH. The path is
> correct though. Also, it does work for GRASS 6.4.0.
> Am I overlooking something, or is it not possible to build QGIS with
> GRASS 7.0 support?
> Rgds, Paulo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120407/956bf61f/attachment.html>
