[Qgis-user] Re: Slope not calculating correctly
mnertinger
maxxnertinger at gmail.com
Tue Apr 10 04:10:15 PDT 2012
Hi Rudi!
I had the same issue using ASTER Data some days ago.
It should also work in the WGS84 projection by using the GDAL based DEM
utilities.
Just use the slope analysis and put a hook on the checkbox with "use percent
slope (instead of degrees)"
And be sure to save the output in the same folder as your original DEM.
Let me know how it worked out!
Cheers,
Max
View this message in context: http://osgeo-org.1560.n6.nabble.com/Slope-not-calculating-correctly-tp4738276p4742353.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
