[Qgis-user] Edition of PostGIS table with 2 geometries
pcreso at pcreso.com pcreso at pcreso.com
Wed Apr 11 15:23:22 PDT 2012
    > On 04/11/2012 10:15 PM, Piotr Pachół wrote:
> Hello,
> I have table in PosGIS, which has 2 geometries: geometry(Point)
      > and geometry(MultiPolygon).
> Two geometries is because each object/record of table has 2
      > representations: as point and as polygon.
      > In Qgis this table is displayed as two layers: point layer and
      > polygon layer.
> When I create new object I have problem, because I can't add/edit
      > at the same time two geometries in one record of table.
> When I add one object in  point layer and one object in polygon
      > layer I have 2 records in PostGIS table - I would like to have one
      > record.
This is the correct behaviour. You are telling QGIS to create a new record each time, so it does. Twice. What you need to do is create the new record (with either a point or polygon geometry), then update (edit)  this record to add the missing geometry value.
You could have PostGIS apply a trigger upon the creation of a record (with a new polygon geometry) to populate the point geometry column with either the polygon centroid (which may lie outside the polygon) or an arbitrary point lying within the polygon.
Brent Wood
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120411/786bb3c5/attachment.html>
