[Qgis-user] RE: QGIS starting problem....
S. Subramanya subbu.subramanya at gmail.com
Wed Apr 11 20:51:45 PDT 2012
The problem was solved per suggestion by copying libtiff.dll from `Quantum
GIS Wroclaw\bin' folder to `Windows\System 32' folder. Prior to that, I
renamed libtff.dll in the System32 folder as libtiff.dll.bak so that, in
case some other programs are using it, I could revert and activate it.
Cheers,
Subbu.
Date: Wed, 11 Apr 2012 12:24:29 +0200
From: Bernd Laskowski <Bernd.Laskowski at Reichshof.de>
Subject: [Qgis-user] RE: QGIS starting problem.... (S. Subramanya)
To: qgis-user at lists.osgeo.org
Message-ID: <4F855BDD.6040403 at Reichshof.de
Content-Type: text/plain; charset="iso-8859-15"
perhaps there are more than one libtiff.dll files on your computer. For
example in the system32 folder.
The wrong one could be found first. In this one the called procedure
dosn't exist.
Be carefull. An other Program could need this file.
I had have the same Problem with qt dll files which are installed from
elster formular programm in the system32 folder.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120412/f54b6112/attachment.html>
