[Qgis-user] Failing to open a valid shp file
Jeremy Dunck
jdunck at gmail.com
Thu Apr 12 18:35:10 PDT 2012
Hmm, interesting.
$ sudo lsof | grep -i 'qgis' | wc -l
363
$ ulimit
unlimited
Even so, I tried it:
launchctl limit maxfiles 1024
$ ulimit
unlimited
Launched qgis, and it did indeed let me add more shapes without complaint.
So now I'm wondering what is enforcing this limit..
On Thu, Apr 12, 2012 at 5:59 PM, William Kyngesburye
<woklist at kyngchaos.com> wrote:
> There is a hard limit on OS X to how many files a single process (ie QGIS app) can have open at a time. I believe it's 256, which when you count the 3 basic files of a shapefile set, means you can have 85 shapefiles in a project.
> When QGIS tries to open that 86th shapefile it can only open 2 of the 3 files, and without the 3rd file it becomes unrecognizable, thus the misleading error.
> Last time I looked into this, it unfortunately couldn't be globally changed for all applications. It's possible to override the limit for individual processes, but the method only works from a Terminal, which is not the normal way to start applications.
> It may be possible now with launchctl. Try running this command in a Terminal, then run QGIS normally and open your project with >85 shapefiles:
> On Apr 12, 2012, at 6:48 PM, Jeremy Dunck wrote:
>> I'm using the shapefile found here:
>> http://www.flsenate.gov/Session/Redistricting/Plan/s016s9030
>> specifically:
>> http://www.flsenate.gov/PublishedContent/Session/Redistricting/Plans/S016S9030/S016S9030_shp.zip
>> If I open just this one file, it works. If I open it in a project w/
>> a bunch of other shapes, it fails - most of the time. I repeatedly
>> tried opening the same file (without changing anything on the
>> filesystem) and finally, it worked. The only difference I can see is
>> that I removed a different shp from the project before adding this one
>> succeeded.
>> The error I'm getting is:
>> "/path/to/20120401/s000s9008.shp is not a valid or recognized data source"
>> I've attached a screenshot of my About page; this is on Mac 10.7.3.
>> I tried to see if there was a logfile but no dice:
>> $ sudo lsof | grep -i qgis
>> How can I troubleshoot this?
>> <Screen Shot 2012-04-12 at 4.37.47 PM.png>_______________________________________________
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
