[Qgis-user] Only show some of the contours using a query builder
jonathanmoules at warwickshire.gov.uk jonathanmoules at warwickshire.gov.uk
Fri Apr 13 07:46:28 PDT 2012
Mostly guessing here but it looks like the query builder in QGIS uses % as
its modulo operator.
Try more traditional syntax like (this returns no errors in my QGIS):
"Elevation"%25=0
(Although wouldn't you want that to be 100 not 25?)
Jonathan
To:     qgis-user at lists.osgeo.org
Date:   13/04/2012 15:37
Subject:        [Qgis-user] Only show some of the contours using a query
builder
Sent by:        qgis-user-bounces at lists.osgeo.org
I have a shapefile containing 5 foot contours and I would only like to
show
100 foot contours.  I am guessing I could use the query builder in the
layer
properties but I don't know how to write the query.
Is this possible?
I know how to do this in ArcGIS (MOD ( "Elevation", 25) = 0) but the same
code does not work in QGIS.
View this message in context:
http://osgeo-org.1560.n6.nabble.com/Only-show-some-of-the-contours-using-a-query-builder-tp4878790p4878790.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120413/c83944ac/attachment.html>
