[Qgis-user] Clipper cannot computer bounding box of cultine
Carlos Cerdán sig.upagu at gmail.com
Sat Apr 14 17:45:48 PDT 2012
Same problem with "extents" (QGIS 1.7.4 - Ubuntu 11.10). My solution:
don't cut an active layer, try  "select" button in order to QGIS finds
the raster file. It works for me.
Carlos Cerdán
El 14/04/12 06:02, Hannah Pethen escribió:
> I am using QGIS to clip a raster using a mask. All files and the
> project are in the same projection. I have tried with both 'on the fly
> reprojection' on and off. I have also tried clipping the raster in the
> form of a tif and as a asc file, but whatever I try the error comes up
> 'Cannot compute bounding box of cutline'. I have checked that the
> boundaries of the vector file are within the boundaries of the raster,
> but no matter how far inside the raster the vector file boundaries
> fall it still fails. I tried using 'extents' and it worked, but I need
> to be able to use the mask.
> Does anyone know what the problem is, or is this a bug.
> Thanks
> Hannah
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120414/c2eaf836/attachment.html>
