[Qgis-user] Measuring distance between points in vector layer
Harald Hofmann
harald.hofmann at monash.edu
Tue Apr 17 04:59:42 PDT 2012
Hi Micha,
you are a champ. Thanks heaps that works really well.
I had a few issues with v.in.lines as there was a line created after the
protocol but it wasn't. I think the file wasn't read properly.
It worked when I used the command with the in=- option and copying the x
y coordinates in the Terminal.
Thanks again.
Cheers,
Harald
On 17/04/12 21:42 , Micha Silver wrote:
> On 04/17/2012 02:13 PM, G. Allegri wrote:
>> Now run v.distance as:
>> v.distance from=gps_point to=river_line upload=to_along
>> column=along out=connectors
>> # The output parameter hold the line segments connecting each
>> point to the river_line. It's required by the module to run, by
>> has no significance for you.
>> I have never tested the to_along upload type, but what is considered
>> the "to" nearest point in this case? I mean, you will have the
>> original points located on the endpoints of the line, isn't the
>> nearest point the endpoint itself?
> IIUC, v.distance finds the distance along the line from each point to
> the *vertex* on the line closest to that point.
> But in this particular case, since we're creating the line from the
> same input points, the line vertices and the points are all the same,
> so I think it shouldn't matter. The distance from the points to the
> nearest vertex will always be 0, and 'to_along' should give the
> distance along the line to that vertex=point.
> If I'm wrong, someone on the list with more experience will jump up...
>> giovanni
>> Cheers,
>> Micha
>>> Help would be really appreciated. And I am sorry if that has
>>> been asked before but I couldn't find a thread dealing with that.
>>> Best regards,
>>> Harald
>> Micha Silver
>> 052-3665918
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> This mail was received via Mail-SeCure System.
Harald Hofmann
Research Fellow PhD - Hydrogeology
School of Geosciences
Monash University
Wellington Road
Clayton, Victoria 3800
Australia
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120417/fc1c73fb/attachment.html>
