[Qgis-user] Re: GPX, OS Grid References and Google Earth
T. Gray Shaw tgray at arborartist.com
Mon Apr 23 08:24:42 PDT 2012
I have a GPSmap 60CSx.  I used Garmin BaseCamp 3.2.2 or 2.1.2 to upload waypoints from the GPS unit and export a .csv file.  I had to trim extraneous data in the .csv before it would import into QGIS.
- Gray
Mac OS 10.6.8
QGIS 1.7.2 (impressed by users who build nightly, but not there yet myself)
On Apr 23, 2012, at 6:57 AM, Des Callaghan wrote:
> Many thanks Lene and Nick, this worked a treat. Combined with the Google
> Satellite basemap, imported using the fantastic 'OpenLayers' plugin, this is
> just what I needed. Many thanks for your help. Best wishes, Des
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Nick Hopton
> Sent: 23 April 2012 11:04
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Re: GPX, OS Grid References and Google Earth
> Hi Des, just to add a lttle to what Lene wrote. As mentioned, import the GPX
> file to QGIS, then save it as a EPSG:27700 projected shapefile. To do this
> right-click on the GPX file in the layers panel, go 'Save As...' and set
> 'Format' to 'ESRI Shapefile'. Set the CRS for the new shapefile by clicking
> to the right of 'CRS', and picking 'Selected CRS', then press the 'Browse'
> button. In the window that appears enter '27700' (without the quotes) in the
> 'Filter' field. Highlight 'OSGB 1936 / British National Grid' in the list
> below and press 'OK'. Then give the new shapefile a name and click 'OK'.
> Next, load the new shapefile into QGIS, right-click on it in the layers
> panel and go 'Set Project CRS from Layer'. You can now add OS grid
> coordinates to the shapefile's attribute table. To do this, highlight the
> layer in the layers panel and (from the top menu bar) go Vector -> Geometry
> Tools -> Export/Add geometry columns. All you need to do here is tick 'Save
> to new shapefile', give the new file a name and press 'OK'.
> Now load the new shapefile and have a look at the attribute table
> (right-click on the layer in the layers panel and go 'Open Attribute
> Table'). You should find that it contains two new columns, one for OS
> eastings (x-ordinates) and the other for northings (y-ordinates). The
> ordinates form OS grid coordinates, not grid references (ie. SD4568798345
> will be shown as 345687 498345, for example). QGIS doesn't know about
> Ordnance Survey grid references I'm afraid, but if this is a problem then
> come back.
> Nick.
> http://osgeo-org.1560.n6.nabble.com/GPX-OS-Grid-References-and-Google-Earth-
> tp4907061p4909729.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2012.0.1913 / Virus Database: 2411/4953 - Release Date: 04/22/12
T. Gray Shaw
ISA Certified Arborist # WE-1037
Redway and Berkeley, CA
510 418-3420
Skype: tgrayshaw
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120423/13971865/attachment.html>
