[Qgis-user] Re: GPX, OS Grid References and Google Earth
Lee Hachadoorian Lee.Hachadoorian+L at gmail.com
Mon Apr 23 10:25:39 PDT 2012
Can I ask why it's recommended to use the GPS Tool plugin? I was recently
working with GPX data and just used the standard Add Vector Layer.
Best,
--Lee
On Mon, Apr 23, 2012 at 12:22 PM, Nick Hopton <nhopton at gmail.com> wrote:
> Des Callaghan wrote
> > Many thanks Lene and Nick, this worked a treat. Combined with the Google
> > Satellite basemap, imported using the fantastic 'OpenLayers' plugin, this
> > is
> > just what I needed. Many thanks for your help. Best wishes, Des
> Just a couple of points arising, Des. It's very useful to be able to
> overlay
> your own data on OpenLayers to get a visual indication of of how well it
> fits. But OpenLayers use a very peculiar CRS which can make it unsafe to do
> thing like use the tape measure for measuring distances or the area tool
> for
> measuring areas. The other thing is that closing OpenLayers will leave your
> project CRS in the Google Projection, fix this by resetting your project
> projection to your shapefile layer projection. If you would like some GB
> base maps to use with your GPS data you could try OS OpenData VectorMap
> District Rasters. They are pretty base too, but accurate.
> Nick.
> http://osgeo-org.1560.n6.nabble.com/GPX-OS-Grid-References-and-Google-Earth-tp4907061p4910779.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120423/53567c19/attachment.html>
