[Qgis-user] Sextante algorithms from gvSIG CE
Victor Olaya
volayaf at gmail.com
Wed Apr 25 00:09:00 PDT 2012
Nathan, I know that it is a big turn of...and that is why I decided
not to use the SAGA python bindings (they are too hard to install for
the average user) Instead, SEXTANTE runs SAGA on the command line, so
you just have to install SAGA for windows (very very easy), and then
in the SEXTANTE configuration tell SEXTANTE which is the SAGA folder.
That should be enough :-)
Regards
El día 25 de abril de 2012 09:01, Nathan Woodrow <madmanwoo at gmail.com> escribió:
> Victor,
> Do you know if the SAGA python bindings are available for Windows? I would
> really like to test all this out but last time I looked you had to compile
> SAGA python bindings for windows and that is a pretty big turn off for
> users.
> - Nathan
> On Wed, Apr 25, 2012 at 4:48 PM, Victor Olaya <volayaf at gmail.com> wrote:
>> There is, in fact, a category called "request for algorithms" at
>> http://hub.qgis.org/projects/sextante/issues
>> I still have to think about how to create those new algorithms. The
>> original Java SEXTANTE (the one in gvSIG CE) contained the SAGA
>> algorithms ported to Java, plus quite a few new ones that I developed
>> myself. Since now SEXTANTE for QGIS uses SAGA, I am thinking that
>> maybe it would be good to write those missing algorithms not in QGIS
>> directly, but in SAGA instead, so I contribute to the project, while
>> algorithms can still be used from QGIS.
>> Anyway, whatever algorithm you are missing, just add it there and we
>> will for sure work on it. My idea is to have a comprehensive list of
>> algorihtms available in SEXTANTE for QGIS, much more complete that the
>> one in SEXTANTE for gvSIG, since now the software is improved and it
>> is easier to extend it.
>> As donovan said, this is just the beginning :-)
>> Regards
>> El día 25 de abril de 2012 03:14, Donovan Cameron
>> <sault.don at gmail.com> escribió:
>> > Sextante toolbox is something that just got introduced to QGIS, so I
>> > think
>> > eventually it would.
>> > I suggest for the meantime you
>> > visit http://hub.qgis.org/projects/sextante/issues and request any tools
>> > you
>> > would like to see added.
>> > Regards,
>> > Donovan
>> > On Tue, Apr 24, 2012 at 3:25 PM, Piotr Pachół <piotrpachol at gmail.com>
>> > wrote:
>> >> Hello,
>> >> Are any plans to implement in Sextante plugin of Qgis algorithms which
>> >> are
>> >> already available in gvSIG CE ?
>> >> I mean algorithms from such groups: 3D, TIN, Visibility and lighting
>> >> and
>> >> many others.
>> >> Regards,
>> >> Piotr
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> >> Qgis-user at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
