[Qgis-user] Sextante algorithms from gvSIG CE
Angelos Tzotsos
gcpp.kalxas at gmail.com
Wed Apr 25 08:53:54 PDT 2012
Hi Victor,
The same applies for OTB right?
You use the bandled applications in OTB, not the python wrappings.
FYI I have created an RPM package of sextante for openSUSE users:
https://build.opensuse.org/package/show?package=qgis-sextante&project=home%3Atzotsos%3AApplication%3AGeo
I plan to keep this around and update it every week or so until the
plugin is integrated to main source. I am still not sure if this should
go to the official GEO repository yet.
Regards,
Angelos
On 04/25/2012 10:09 AM, Victor Olaya wrote:
> Nathan, I know that it is a big turn of...and that is why I decided
> not to use the SAGA python bindings (they are too hard to install for
> the average user) Instead, SEXTANTE runs SAGA on the command line, so
> you just have to install SAGA for windows (very very easy), and then
> in the SEXTANTE configuration tell SEXTANTE which is the SAGA folder.
> That should be enough :-)
> Regards
> El día 25 de abril de 2012 09:01, Nathan Woodrow<madmanwoo at gmail.com> escribió:
>> Victor,
>> Do you know if the SAGA python bindings are available for Windows? I would
>> really like to test all this out but last time I looked you had to compile
>> SAGA python bindings for windows and that is a pretty big turn off for
>> users.
>> - Nathan
>> On Wed, Apr 25, 2012 at 4:48 PM, Victor Olaya<volayaf at gmail.com> wrote:
>>> There is, in fact, a category called "request for algorithms" at
>>> http://hub.qgis.org/projects/sextante/issues
>>> I still have to think about how to create those new algorithms. The
>>> original Java SEXTANTE (the one in gvSIG CE) contained the SAGA
>>> algorithms ported to Java, plus quite a few new ones that I developed
>>> myself. Since now SEXTANTE for QGIS uses SAGA, I am thinking that
>>> maybe it would be good to write those missing algorithms not in QGIS
>>> directly, but in SAGA instead, so I contribute to the project, while
>>> algorithms can still be used from QGIS.
>>> Anyway, whatever algorithm you are missing, just add it there and we
>>> will for sure work on it. My idea is to have a comprehensive list of
>>> algorihtms available in SEXTANTE for QGIS, much more complete that the
>>> one in SEXTANTE for gvSIG, since now the software is improved and it
>>> is easier to extend it.
>>> As donovan said, this is just the beginning :-)
>>> Regards
>>> El día 25 de abril de 2012 03:14, Donovan Cameron
>>> <sault.don at gmail.com> escribió:
>>>> Sextante toolbox is something that just got introduced to QGIS, so I
>>>> think
>>>> eventually it would.
>>>> I suggest for the meantime you
>>>> visit http://hub.qgis.org/projects/sextante/issues and request any tools
>>>> you
>>>> would like to see added.
>>>> Regards,
>>>> Donovan
>>>> On Tue, Apr 24, 2012 at 3:25 PM, Piotr Pachół<piotrpachol at gmail.com>
>>>> wrote:
>>>>> Hello,
>>>>> Are any plans to implement in Sextante plugin of Qgis algorithms which
>>>>> are
>>>>> already available in gvSIG CE ?
>>>>> I mean algorithms from such groups: 3D, TIN, Visibility and lighting
>>>>> and
>>>>> many others.
>>>>> Regards,
>>>>> Piotr
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
