[Qgis-user] Fwd: wktraster with Postgis 2.0 in QGIS 1.9 on Linux Mint Maya
Mauricio de Paulo mauricio.dev at gmail.com
Fri Aug 31 06:04:34 PDT 2012
Could you please do one easy test? Try creating a table without a number
as first character in it's name.
I may have experienced this before. I don't remember exactly but i
suspect that this is a postgresql constraint. I think I should start
using " " on table's name in the plugin.
Mauricio C. M. de Paulo
Engenheiro Cartógrafo
Mestrando em Sensoriamento Remoto (INPE)
On 08/30/2012 02:47 PM, Brian Fitzgerald wrote:
> Etienne,
> Thanks again for all your help... I know this isn't your job so I
> really appreciate it.
> I removed QGIS, and my qgis.org/debian <http://qgis.org/debian> ppa
> and changed it to /ubuntu-nightly.  Reinstalled, and now QGIS does
> show gdal 1.9 under help -> about.  :) :)
> However,  I'm still experiencing the exact same error.  See attached
> screenshots.
> - Brian
> On Thu, Aug 30, 2012 at 9:40 AM, Etienne Tourigny
> <etourigny.dev at gmail.com <mailto:etourigny.dev at gmail.com>> wrote:
>     Like I said in previous mail, use the
>     http://qgis.org/ubuntugis-nightly and ubuntugis-unstable repos.
>     Etienne
>     On Thu, Aug 30, 2012 at 10:36 AM, Giovanni Manghi
>     <giovanni.manghi at faunalia.pt <mailto:giovanni.manghi at faunalia.pt>>
>     wrote:
>     > There are 2 nightly repos, one uses ubuntugis packages,
>     including the latest
>     > gdal.
>     > On Aug 30, 2012 1:51 PM, "Mauricio de Paulo"
>     <mauricio.dev at gmail.com <mailto:mauricio.dev at gmail.com>> wrote:
>     >> Don't quote me on this, but I have a memory of the nightly ppas
>     not being
>     >> linked against the latest gdal released.
>     >> On 08/30/2012 09:42 AM, Brian Fitzgerald wrote:
>     >> Yeah... I've been using the nightly ppas
>     >> Brian Fitzgerald
>     >> bkfitz at gmail.com <mailto:bkfitz at gmail.com>
>     >> 803-426-3469 <tel:803-426-3469>
>     >> Sent from my mobile phone
>     >> On Aug 30, 2012 8:39 AM, "Etienne Tourigny"
>     >> wrote:
>     >>> Hi,
>     >>> If you want the nightlies ( which I don't recommend for
>     production)
>     >>> you should be using these (and only these)
>     >>> deb http://qgis.org/ubuntugis-nightly precise main
>     >>> deb-src http://qgis.org/ubuntugis-nightly precise main
>     >>> deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
>     >>> precise main
>     >>> For a more stable, but still recent, use ubuntugis-unstable (only)
>     >>> < remove other repos, and remove anything related to qgis
>     (including
>     >>> gdal)
>     >>> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
>     >>> sudo apt-get update
>     >>> sudo apt-get install qgis
>     >>> On Wed, Aug 29, 2012 at 5:25 PM, Brian Fitzgerald
>     <bkfitz at gmail.com <mailto:bkfitz at gmail.com>>
>     >>> wrote:
>     >>> > Scratch previous email... I just went to QGIS -> about and
>     found that
>     >>> > QGIS
>     >>> > is "Compiled against GDAL/OGR 1.7.3" even though I installed
>     the 1.9
>     >>> > GDAL
>     >>> > libaries before I install QGIS.  Now what?
>     >>> > On Wed, Aug 29, 2012 at 4:22 PM, Brian Fitzgerald
>     >>> > wrote:
>     >>> >> How do I figure out what version of GDAL my QGIS is using... I
>     >>> >> reinstalled
>     >>> >> everything (QGIS nightlies, gdal from the unstable-gis
>     ppas, postgres
>     >>> >> and
>     >>> >> postgis) and am running into the same problem.  I checked
>     in Synaptic
>     >>> >> and
>     >>> >> see both 1.7 and 1.9 gdal libraries installed.
>     >>> >> Thx for all your help!
>     >>> >> - Brian
>     >>> >> On Tue, Aug 28, 2012 at 3:29 PM, Mauricio de Paulo
>     >>> >>> Hi, Brian and Etienne.
>     >>> >>> Well, GDAL 1.7.3 was one of the first efforts to read
>     postgis raster,
>     >>> >>> back in the release candidate days. A few months before
>     the release
>     >>> >>> of
>     >>> >>> postgis 2.0 there was a major change in the raster storage
>     and some
>     >>> >>> code was
>     >>> >>> discontinued. GDAL 1.9.0 was the first release after
>     postgis 2.0 was
>     >>> >>> released so it's the first version that is compatible.
>     >>> >>> Fortunately, vector data is a mature standard inside
>     postgis and
>     >>> >>> didn't
>     >>> >>> suffer any major changes that could break previous working
>     code.
>     >>> >>> Even though we were all notified by these changes, some of our
>     >>> >>> previous
>     >>> >>> work doesn't work with the current version. It was a huge
>     improvement
>     >>> >>> in
>     >>> >>> raster storage and metadata retrieval, so we have to cope
>     with it.
>     >>> >>> I'm releasing the new plugin version with the weak loader
>     tonight. It
>     >>> >>> should be enough to upload one untiled raster with no
>     overviews to
>     >>> >>> the
>     >>> >>> database.
>     >>> >>> I'm using ubuntugis' repositories. The gdal package
>     available on it
>     >>> >>> is
>     >>> >>> version 1.9.1 so you might want to try those binaries,
>     since they
>     >>> >>> work
>     >>> >>> pretty well.
>     >>> >>> All the best,
>     >>> >>> On 08/28/2012 04:17 PM, Brian Fitzgerald wrote:
>     >>> >>> I'm showing GDAL version 1.7.3-6 in Synaptic... so that
>     could be my
>     >>> >>> problem... but wouldn't I also be experiencing loading
>     postgis 2.0
>     >>> >>> vectors?
>     >>> >>> - Brian
>     >>> >>> On Tue, Aug 28, 2012 at 3:01 PM, Mauricio de Paulo
>     wrote:
>     >>> >>>> Hi Brian,
>     >>> >>>> I downloaded the sample data and imported to my database
>     and it
>     >>> >>>> seems to
>     >>> >>>> work pretty well. I'm using QGIS 1.8, postgis 2.0,
>     postgres 9.1.5,
>     >>> >>>> gdal
>     >>> >>>> 1.9.1 on ubuntu 12.04.
>     >>> >>>> Sorry for my ignorance but what GDAL version is being
>     released with
>     >>> >>>> linux mint? I couldn't find anywhere online.
>     >>> >>>> The plugin heavily relies on GDAL to perform the
>     visualization so
>     >>> >>>> you
>     >>> >>>> need the latest GDAL available to get a decent performance.
>     >>> >>>> From my first tests I can say that GDAL 1.9.1 has greatly
>     improved
>     >>> >>>> performance and the next versions should improve even
>     further. The
>     >>> >>>> fastest
>     >>> >>>> visualization that I have achieved with version 1.9.1 is
>     with single
>     >>> >>>> tiled
>     >>> >>>> raster files. Unfortunately I wasn't able to get GDAL to use
>     >>> >>>> overviews so
>     >>> >>>> far, but Jorge (GDAL's postgis raster developper) is
>     researching on
>     >>> >>>> this
>     >>> >>>> subject.
>     >>> >>>> GDAL versions bellow 1.9 should not be able to read
>     postgis 2.0.
>     >>> >>>> Unfortunately, since postgis 2.0 release, the python
>     loader was
>     >>> >>>> discontinued in postgis source. Recently I have started
>     to make the
>     >>> >>>> necessary changes starting from the old code to get it to
>     work. I
>     >>> >>>> don't know
>     >>> >>>> if this is going to be a good solution but it seems
>     possible. I'm
>     >>> >>>> trying to
>     >>> >>>> avoid the platform-dependent compilation that postgis'
>     raster loader
>     >>> >>>> has in
>     >>> >>>> version 2.0 now that it's being entirely written in C. In
>     the future
>     >>> >>>> I
>     >>> >>>> should probably release a simple uploader with the
>     plugin, without
>     >>> >>>> all those
>     >>> >>>> options until I'm certain that everything is working
>     according to
>     >>> >>>> the
>     >>> >>>> standard.
>     >>> >>>> I'm copying this mail to the list to allow other users to
>     find this
>     >>> >>>> thread later.
>     >>> >>>> On 08/28/2012 03:56 PM, Brian Fitzgerald wrote:
>     >>> >>>> PS - Im also unable to "load" raster data into PostGIS
>     using the
>     >>> >>>> plugin... the icon is greyed out for some reason.
>     >>> >>>> - Brian
>     >>> >>>> On Tue, Aug 28, 2012 at 2:20 PM, Brian Fitzgerald
>     >>> >>>> wrote:
>     >>> >>>>> Sure.
>     >>> >>>>> I'm running Ubuntu Mint 13 Cinnamon with Postgres 1.9.5,
>     Postgis
>     >>> >>>>> 2.0.
>     >>> >>>>> and QGIS 1.9.0
>     >>> >>>>> I followed this install tutorial:
>     http://linfiniti.com/2012/05/installing-postgis-2-0-on-ubuntu/
>     >>> >>>>> I loaded the sample vector shapefile into my new 'training'
>     >>> >>>>> database
>     >>> >>>>> and opened it in QGIS with no problem.
>     >>> >>>>> I loaded the sample raster data using the command in the
>     tutorial,
>     >>> >>>>> it
>     >>> >>>>> loaded with no problems.  I ran the test query in the
>     tutorial, no
>     >>> >>>>> problem.
>     >>> >>>>> I went into QGIS to load the raster and got an error
>     that referred
>     >>> >>>>> to some
>     >>> >>>>> missing python dependencies (i think it was the
>     python-psycopg
>     >>> >>>>> libs)... so I
>     >>> >>>>> went to Synaptic and loaded the following:
>     >>> >>>>> Installed the following packages:
>     >>> >>>>> libjs-sphinxdoc (1.1.3+dfsg-2ubuntu2.1)
>     >>> >>>>> libjs-underscore (1.1.6-1ubuntu2)
>     >>> >>>>> python-dbg (2.7.3-0ubuntu2)
>     >>> >>>>> python-psycopg2 (2.4.5-1)
>     >>> >>>>> python-psycopg2-dbg (2.4.5-1)
>     >>> >>>>> python-psycopg2-doc (2.4.5-1)
>     >>> >>>>> python2.7-dbg (2.7.3-0ubuntu3.1)
>     >>> >>>>> python3 (3.2.3-0ubuntu1)
>     >>> >>>>> python3-dbg (3.2.3-0ubuntu1)
>     >>> >>>>> python3-minimal (3.2.3-0ubuntu1)
>     >>> >>>>> python3-psycopg2 (2.4.5-1)
>     >>> >>>>> python3-psycopg2-dbg (2.4.5-1)
>     >>> >>>>> python3.2 (3.2.3-0ubuntu3)
>     >>> >>>>> python3.2-dbg (3.2.3-0ubuntu3)
>     >>> >>>>> python3.2-minimal (3.2.3-0ubuntu3)
>     >>> >>>>> I then came back to QGIS to open the raster and no
>     longer get the
>     >>> >>>>> python error... this time it brings up the "Load PostGIS
>     Raster
>     >>> >>>>> Layer" just
>     >>> >>>>> fine and displays my sample raster.  I click on the
>     raster name in
>     >>> >>>>> the table
>     >>> >>>>> and it puts it down in the "Table Name" input box.  I
>     then click on
>     >>> >>>>> OK and
>     >>> >>>>> get a window that pops up saying "Could Not Load Layer".
>      I click
>     >>> >>>>> ok to this
>     >>> >>>>> and another window comes up that says:  "Could not load PG:
>     >>> >>>>> dbname=training
>     >>> >>>>> host=localhost user=postgres password=xxxxxx port=5432
>     >>> >>>>> schema=public
>     >>> >>>>> table=srtm_4326 mode=2".  When I click ok to this, the
>     window
>     >>> >>>>> diappears and
>     >>> >>>>> nothing happens.
>     >>> >>>>> I also tried one of our ortho geotiffs using the
>     following command
>     >>> >>>>> and
>     >>> >>>>> get the same results:
>     >>> >>>>> postgres at minty /home/rcgeoadmin/Temp $ raster2pgsql -s 4326
>     >>> >>>>> /home/rcgeoadmin/Temp/979903.tif | psql training
>     >>> >>>>> Processing 1/1: /home/rcgeoadmin/Temp/979903.tif
>     >>> >>>>> Warning 1: TIFFReadDirectory:Unknown field with tag
>     33919 (0x847f)
>     >>> >>>>> encountered
>     33919 (0x847f)
>     >>> >>>>> encountered
>     33919 (0x847f)
>     >>> >>>>> encountered
>     33919 (0x847f)
>     >>> >>>>> encountered
>     33919 (0x847f)
>     >>> >>>>> encountered
>     33919 (0x847f)
>     >>> >>>>> encountered
>     33919 (0x847f)
>     >>> >>>>> encountered
>     33919 (0x847f)
>     >>> >>>>> encountered
>     33919 (0x847f)
>     >>> >>>>> encountered
>     33919 (0x847f)
>     >>> >>>>> encountered
>     33919 (0x847f)
>     >>> >>>>> encountered
>     33919 (0x847f)
>     >>> >>>>> encountered
>     33919 (0x847f)
>     >>> >>>>> encountered
>     33919 (0x847f)
>     >>> >>>>> encountered
>     33919 (0x847f)
>     >>> >>>>> encountered
>     33919 (0x847f)
>     >>> >>>>> encountered
>     >>> >>>>> BEGIN
>     >>> >>>>> NOTICE:  CREATE TABLE will create implicit sequence
>     >>> >>>>> "979903_rid_seq"
>     >>> >>>>> for serial column "979903.rid"
>     >>> >>>>> NOTICE:  CREATE TABLE / PRIMARY KEY will create implicit
>     index
>     >>> >>>>> "979903_pkey" for table "979903"
>     >>> >>>>> CREATE TABLE
>     >>> >>>>> INSERT 0 1
>     >>> >>>>> COMMIT
>     >>> >>>>> - Brian
>     >>> >>>>> On Tue, Aug 28, 2012 at 8:24 AM, Mauricio de Paulo
>     wrote:
>     >>> >>>>>> Hi, Brian.
>     >>> >>>>>> Could you please elaborate a little more about what
>     were you
>     >>> >>>>>> trying to
>     >>> >>>>>> do and what raster configuration you were using? Is it
>     tiled or
>     >>> >>>>>> untiled? One
>     >>> >>>>>> single raster file in the table? Did you build overviews?
>     >>> >>>>>> All the best,
>     >>> >>>>>> On 08/27/2012 07:00 PM, Brian Fitzgerald wrote:
>     >>> >>>>>> ---------- Forwarded message ----------
>     >>> >>>>>> From: "Brian Fitzgerald" <bkfitz at gmail.com
>     >>> >>>>>> Date: Aug 27, 2012 4:57 PM
>     >>> >>>>>> Subject: wktraster with Postgis 2.0 in QGIS 1.9 on
>     Linux Mint Maya
>     >>> >>>>>> To: <wonder.sk at gmail.com <mailto:wonder.sk at gmail.com>>
>     >>> >>>>>> I'm having problems loading a Postgis 2.0 raster layer
>     into QGIS
>     >>> >>>>>> 1.9
>     >>> >>>>>> using your wktraster extension.
>     >>> >>>>>> The menu comes up, but I get a "could not load layer"
>     >>> >>>>>> Then a window that says:
>     >>> >>>>>> "Could not load PG: dbname=training host=localhost
>     user=postgres
>     >>> >>>>>> password=topology4 port=5432 table= mode=2"
>     >>> >>>>>> Any ideas?
>     >>> >>>>>> Brian Fitzgerald, PMP, GISP
>     >>> >>>>>> 803.426.3469 <tel:803.426.3469>
>     >> _______________________________________________
>     >> Qgis-user mailing list
>     >> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> 803.426.3469
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120831/1db43454/attachment.html>
