[Qgis-user] python error
Jeffrey Durrence
jeffrey.durrence at mcleanengineering.com
Mon Dec 3 05:50:57 PST 2012
Summary: Updating from nightly builds breaks python-qgis-common
I've experienced the same problem as reported by Matteo. I see where someone posted on stackexchange but it was closed as off-topic.
http://gis.stackexchange.com/questions/29094/how-to-install-qgis-on-ubuntu-12-04
Any insight on resolving this would be terrific.
JD
My Platform =
Ubuntu 12.04 64 Bit,
QGIS version 1.9.0-Master
QGIS code revision exported
Compiled against Qt4.8.1
Running against Qt4.8.1
Compiled against GDAL/OGR1.7.3
Running against GDAL/OGR1.7.3
GEOS Version 3.2.2
PostgreSQL Client Version 9.1.5
SpatiaLite Version 3.0.0-beta
QWT Version 5.2.2
PROJ.4 Version 470
QScintilla2 Version
> 6. python error (Matteo Ghetta)
> Message: 6
> Date: Mon, 3 Dec 2012 14:39:34 +0100
> From: Matteo Ghetta <matteo.ghetta at gmail.com>
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] python error
> Message-ID:
> <CAMMN2u2sve7tpML6641NHd=ipSOfhLmqRcKieEhaQZ_JbiPK+Q at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi guys,
> I've updated qgis from the nightly repos but I got some errors
> (ubuntu
> 12.04):
> Configurazione di python-qgis-common
> (1.9.0+git20121201+80fa7aa~precise-ubuntugis1)...
> Compiling
> /usr/share/qgis/python/plugins/sextante/admintools/httplib2/__init__.py
> SyntaxError: ('from __future__ imports must occur at the beginning of
> the
> file',
> ('/usr/share/qgis/python/plugins/sextante/admintools/httplib2/__init__.py',
> 26, None, 'from __future__ import generators\n'))
> pycentral: pycentral pkginstall: error byte-compiling files (496)
> dpkg: errore nell'elaborare python-qgis-common (--configure):
> il sottoprocesso vecchio script di post-installation ha restituito
> lo
> stato di errore 1
> dpkg: problemi con le dipendenze impediscono la configurazione di
> python-qgis:
> python-qgis dipende da python-qgis-common (=
> 1.9.0+git20121201+80fa7aa~precise-ubuntugis1), ma:
> Il pacchetto python-qgis-common non ? ancora configurato.
> dpkg: errore nell'elaborare python-qgis (--configure):
> problemi con le dipendenze - lasciato non configurato
> Segnalazione apport non scritta poich? il messaggio di errore indica
> la
> presenza di un fallimento precedente.
> Si sono verificati degli errori nell'elaborazione:
> python-qgis-common
> python-qgis
> E: Sub-process /usr/bin/dpkg returned an error code (1)
> and starting qgis:
> Impossibile caricare PyQGIS.
> Il supporto Python verr? disabilitato.
> Traceback (most recent call last):
> File "", line 1, in
> ImportError: No module named qgis.core
> Versione Python:
> 2.7.3 (default, Aug 1 2012, 05:27:35)
> [GCC 4.6.3]
> Versione di QGIS:
> 1.9.0-Master 'Master', exported
> And obviously I can't use plugins...
> Some ideas?
> Regards
> Matteo
