[Qgis-user] How to join shapefile tables via their FIDs?
Brad Nesom gisbradokla at live.com
Mon Dec 3 08:27:14 PST 2012
actually I think you probably want the intersect command.
I don't see it in the help so.
Vector> geoprocessing tools> intersect.
Choose your point file first and the polygon layer to overlay with it.
it will append all attributes from the polygon layer to the point layer.
Then you can join the polygon layer to the point layer with the primary key
you create.
On Mon, Dec 3, 2012 at 4:51 AM, haubourg <
regis.haubourg at eau-adour-garonne.fr> wrote:
> Hi,
> FID must be considered as internal identifiers , that can be unstable. I
> guess this is the reason why it is not exposed by gdal drivers and others.
> You should create a dedicated primary key field, this is a better pratice,
> less risky if data changes.
> Régis
> http://osgeo-org.1560.n6.nabble.com/How-to-join-shapefile-tables-via-their-FIDs-tp5020215p5020305.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121203/88a22d8e/attachment.html>
