[Qgis-user] python error
Jeffrey Durrence
jeffrey.durrence at mcleanengineering.com
Mon Dec 3 11:39:54 PST 2012
I wanted to say a big thanks to Matteo for pointing out this fix. I spent lots of time reviewing the "history" of qgis on my current workstation. Unfortunately I've been through several versions of Ubuntu, QGIS and PostGIS on this machine. As a result, I had quite a mix of source entries and/or PPA's, source code and other remnants from previous versions. I have a bad habit of not fully documenting "WHY I have WHAT I have and HOW I have it," and I'm probably not alone in this.
Though perhaps a bit off topic, I'd appreciate any tips from others on best practices for avoiding a broken QGIS installation (resulting from updates). After having been bitten by this a couple of times, I'm tempted to disable updates for long periods of time. I fully understand the disclaimers placed on the nightly builds or other sources described as "unstable," but the most stable releases of the packages that I need are lacking features provided by the newer versions.
I'm okay with the potential risk involved with updating packages from nightly or unstable sources, I'm just looking for a better "undo" procedure when things go wrong and I need to back down to previous versions. I'd appreciate the advice of others.
Thanks,
Jeffrey Durrence
----- Original Message -----
> From: "Matteo Ghetta" <matteo.ghetta at gmail.com>
> To: "Jeffrey Durrence" <jeffrey.durrence at mcleanengineering.com>
> Cc: qgis-user at lists.osgeo.org
> Sent: Monday, December 3, 2012 1:46:25 PM
> Subject: Re: [Qgis-user] python error
> Ok I solved the problem..
> During the updating thw first line of the file __init__.py (stored in
> /usr/share/qgis/python/plugins/sextante/admintools/httplib2) "from
> __future__ import generators" moved to the 26th line of the same
> file. I really don't understand why, but after moving it back to the
> right place, it seems that python (and the plugins) works correctly.
> Cheers
