[Qgis-user] error installing CONTOUR plugin
Irene Palumbo
ire.palumbo at gmail.com
Thu Dec 6 03:44:00 PST 2012
Hello to everyone!!
I need to install the CONTOUR plugin, but I get this error...(I am sorrry if it is written in italian..but I guess you'll understand anyway).
Questo plugin richiede un modulo che non รจ presente (matplotlib)
Impossibile caricare il plugin contour a causa di errore chiamando il metodo classFactory()
File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 164, in startPlugin
plugins[packageName] = package.classFactory(iface)
File "/Users/Irene/.qgis//python/plugins/contour/__init__.py", line 68, in classFactory
from contour import Contour
File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 309, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "/Users/Irene/.qgis//python/plugins/contour/contour.py", line 38, in
import matplotlib as mpl
ImportError: No module named matplotlib
Versione Python:
2.7.1 (r271:86832, Jul 31 2011, 19:30:53)
[GCC 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2335.15.00)]
Versione di QGIS:
1.8.0-Lisboa Lisboa,
Percorso Python: ['/Applications/QGIS.app/Contents/MacOS/../Resources/python', '/Users/Irene/.qgis//python', '/Users/Irene/.qgis//python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/3/Python/2.7', '/Library/Python/2.7/site-packages/numpy-override', '/Library/Frameworks/GDAL.framework/Versions/1.9/Python/2.7/site-packages', '/Library/Frameworks/cairo.framework/Versions/1/Python/2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC', '/Library/Python/2.7/site-packages', '/Library/Python/2.7/site-packages/PIL', '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools', '/Users/Irene/Desktop/QGIS/ANAS']
I downloaded matplotlib, but it says that it is impossible to install the module.
I work with MAC OS X Lion 10.7.5 (11G63) and QGIS version1.8.0
Thanks for the help!!!!!!
Regards,
Irene Palumbo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121206/0c63708d/attachment.html>
