[Qgis-user] Sextante and R not loading shp in qgis_dev
Filipe Dias filipesdias at gmail.com
Thu Dec 6 04:06:53 PST 2012
Hi
R tools on Sextante are not working. I already opened a bug report.
http://hub.qgis.org/issues/6834
On Thu, Dec 6, 2012 at 11:26 AM, Agustin Diez-Castillo
<gvsig.mac at gmail.com>wrote:
> Hi,
> Working with several commands that used to work (like F function- distance
> from a point to nearest event)
> Sextante attempts to read at the wrong location the points layer because
> it puts the file in both the dsn and the layer call
> points =
> readOGR("/Users/adiez/sextante/tempdata/sextanteaddautoincrementalfield12",layer="sextanteaddautoincrementalfield12")
> instead of
> points =
> readOGR("/Users/adiez/sextante/tempdata/",layer="sextanteaddautoincrementalfield12")
> that it's what works in the R console
> QGIS version
> 1.9.0-Master
> QGIS code revision
> 98dc557
> Compiled against Qt
> 4.8.3
> Running against Qt
> 4.8.3
> Compiled against GDAL/OGR
> 1.9.1
> Running against GDAL/OGR
> 1.9.2
> GEOS Version
> 3.3.5
> PostgreSQL Client Version
> 9.1.6
> SpatiaLite Version
> 3.0.1
> QWT Version
> 6.0.1
> PROJ.4 Version
> 480
> QScintilla2 Version
> 2.6.2
> This copy of QGIS writes debugging output.
> Log
> R execution console output
> R version 2.15.2 (2012-10-26) -- "Trick or Treat"
> Copyright (C) 2012 The R Foundation for Statistical Computing
> ISBN 3-900051-07-0
> Platform: i386-apple-darwin9.8.0/i386 (32-bit)
> R is free software and comes with ABSOLUTELY NO WARRANTY.
> You are welcome to redistribute it under certain conditions.
> Type 'license()' or 'licence()' for distribution details.
> Natural language support but running in an English locale
> R is a collaborative project with many contributors.
> Type 'contributors()' for more information and
> 'citation()' on how to cite R or R packages in publications.
> Type 'demo()' for some demos, 'help()' for on-line help, or
> 'help.start()' for an HTML browser interface to help.
> Type 'q()' to quit R.
> library("rgdal")
> Loading required package: sp
> rgdal: (SVN revision 360)
> Geospatial Data Abstraction Library extensions to R successfully loaded
> Loaded GDAL runtime: GDAL 1.9.0, released 2011/12/29
> Path to GDAL shared files:
> /Library/Frameworks/R.framework/Versions/2.15/Resources/library/rgdal/gdal
> Loaded PROJ.4 runtime: Rel. 4.8.0, 6 March 2012, [PJ_VERSION: 480]
> Path to PROJ.4 shared files:
> /Library/Frameworks/R.framework/Versions/2.15/Resources/library/rgdal/proj
> points =
> readOGR("/Users/adiez/sextante/tempdata/sextanteaddautoincrementalfield12.shp",layer="sextanteaddautoincrementalfield12")
> Error in file(paste(dsn, .Platform$file.sep, layer, ".dbf", sep = ""), :
> cannot open the connection
> Calls: readOGR -> ogrInfo -> file
> In addition: Warning message:
> In file(paste(dsn, .Platform$file.sep, layer, ".dbf", sep = ""), :
> cannot open file
> '/Users/adiez/sextante/tempdata/sextanteaddautoincrementalfield12.shp/sextanteaddautoincrementalfield12.dbf':
> Not a directory
> Execution halted
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121206/9f943f0a/attachment.html>
