[Qgis-user] error loading shp to postgis through db manager
Pietro Rossin
pierigis at gmail.com
Thu Dec 6 08:22:35 PST 2012
Hello
every time I try to import shp files to postgis through db manager, if the
shp has a numerical field double, i get an error
Error 7
Errori nella scrittura dell'elemento:
Errore nella creazione di elementi da #0 a #0. L'errore della sorgente dati
รจ:
Errore PostGIS nell'aggiunta delle geometrie: ERROR: numeric field overflow
DETAIL: A field with precision 24, scale 15 must round to an absolute value
less than 10^9.
These fields often are shape lenght and area.
Often but not always, sometimes these are fields that I need to store with
the shp..
If I delete them the problem doesn't appear
Why this error?
Thanks
Pietro
View this message in context: http://osgeo-org.1560.n6.nabble.com/error-loading-shp-to-postgis-through-db-manager-tp5021257.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
