[Qgis-user] shp*join*csv real2string problem
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Sat Dec 8 08:12:16 PST 2012
Am 08.12.2012, 14:35 Uhr, schrieb S. Wagenaar <sw1234 at planet.nl>:
> These articles may be useful:
> Join data from a CSV file:
> http://www.qgis.nl/2012/07/13/koppelen-van-data-uit-csv-bestand/?lang=en
> Directly use data from Excel file:
> http://www.qgis.nl/2012/07/17/direct-gebruiken-van-data-uit-excel-bestand/?lang=en
Seems the excel import is version and/or platform dependent: In dev under
linux mint, it doesn't work at all. Drag and drop produces "blabla.xls is
not a valid or recognized data source" and through the normal vector
adding dialog, there is no way to make the xls visible and selectable.
csvt-files are quite annoying as well. I think "old" excel-versions -> dbf
or openoffice/libreoffice -> dbf are still the easiest ways to produce
joinable tables ... unfortunately.
Maybe the string problem can be solved with mmqgis-plugin-> modify -> Text
to Float (no fitting test data at hand)
Bernd Vogelgesang * Siedlerstrasse 2 * 91083 Baiersdorf * +49-9133-825374
