[Qgis-user] shp*join*csv real2string problem
werner at macho.cc
werner at macho.cc
Sat Dec 8 11:14:57 PST 2012
Hi
I use standard gdal on Linux mint Debian edition without any problems regarding xls.
Probably its a problem of "real" Linux mint but in this case Ubuntu should be affected too.
Kind regards
Werner
Von meinem Android-Gerät gesendet.
-----Original Message-----
To: qgis-user at lists.osgeo.org
Sent: Sa., 08 Dez 2012 20:03
Subject: Re: [Qgis-user] shp*join*csv real2string problem
Hi Bernd,
On Sat, 08. Dec 2012 at 17:12:16 +0100, Bernd Vogelgesang wrote:
> Seems the excel import is version and/or platform dependent: In dev under
> linux mint, it doesn't work at all. Drag and drop produces "blabla.xls is
> not a valid or recognized data source" and through the normal vector
> adding dialog, there is no way to make the xls visible and selectable.
It's not platform, but OGR dependant. I suppose the GDAL/OGR on Linux mint
isn't built with FreeXL[1] support and therefore you can't use Excel files
directly.
Jürgen
[1] https://www.gaia-gis.it/fossil/freexl/
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
committ(ed|ing) to Quantum GIS IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121208/60c4a8a1/attachment.html>
