[Qgis-user] Cannot add sqlite/spatialite layers to qgis (they come in as tables)
Donovan Cameron
sault.don at gmail.com
Sun Dec 9 10:54:33 PST 2012
Not sure if it's helpful, but here is a list of installed spatialite/sqlite
packages.
I noticed there is two packages called libspatialite2 and sqlite2, are
those causing conflicts or something?
It looks like libspatialite2 is a (System Package) meaning it was installed
during initial OS installation from the openSUSE DVD...
Were those two suppose to be gone when libspatialite5 and sqlite3 were
installed?
saultdon at opensuse.linux:~> zypper se -si sqlite spatialite
Loading repository data...
Reading installed packages...
S | Name | Type | Version | Arch |
Repository
i | libqt4-sql-sqlite | package | 4.8.1-2.4.1 | x86_64 |
openSUSE-12.2-Update
i | libqt4-sql-sqlite-32bit | package | 4.8.1-2.4.1 | x86_64 |
i | libspatialite2 | package | 3.0.1-9.1 | x86_64 | (System
Packages)
i | libspatialite5 | package | 4.0.0-1.1 | x86_64 |
openSUSE-12.2-Geo
i | libsqlite3-0 | package | 3.7.12.1-2.1.2 | x86_64 |
openSUSE-12.2-Oss
i | libsqlite3-0-32bit | package | 3.7.12.1-2.1.2 | x86_64 |
openSUSE-12.2-Oss
i | perl-DBD-SQLite | package | 1.35-3.1.2 | x86_64 |
openSUSE-12.2-Oss
i | php5-sqlite | package | 5.3.15-1.12.1 | x86_64 |
i | spatialite-gis | package | 1.0.0c-1.2 | x86_64 |
openSUSE-12.2-Geo
i | spatialite-gui | package | 1.6.0-1.1 | x86_64 |
openSUSE-12.2-Geo
i | spatialite-tools | package | 4.0.0-1.1 | x86_64 |
openSUSE-12.2-Geo
i | sqlite2 | package | 2.8.17-183.1.2 | x86_64 |
openSUSE-12.2-Oss
i | sqlite3 | package | 3.7.12.1-2.1.2 | x86_64 |
openSUSE-12.2-Oss
i | sqlite3-devel | package | 3.7.12.1-2.1.2 | x86_64 |
openSUSE-12.2-Oss
On Sun, Dec 9, 2012 at 11:40 AM, Donovan Cameron <sault.don at gmail.com>wrote:
> I created a sqlite/spatialite db from the spatialite_gui and started to
> import a bunch of shapefiles.
> Some of the things I set were the CRS to EPSG:3005 "BC Albers" and
> the_geom as the name for the geometry field (type is set to auto...)
> Then in spatialite_gui I expanded each new table and built a spatial
> index. I can also right click each the_geom table and see a valid "Map
> Preview".
> But I can't open or load this .sqlite files into either spatialite_gis or
> qgis.
> So I think this could be a problem with my actual OS (openSUSE 12.2 x64 w/
> KDE).
> QGIS loads the layers as tables, not vectors.
> spatialite_gis thrown an error:
> Missing or invalid Spatial Metadata tables:
> - spatial_ref_sys
> - geometry_columns
> Sorry, cowardly quitting ...
> But those tables are in the .sqlite db under the "Metadata" portion.
> From the layer menu in QGIS, I can't create a layer in a sqlite db. It
> says that my layer is invalid and can't be created. Then I can't even see
> this sqlite database (that got created successfully, it's just the layer
> that failed creation) when navigating from the add vector window. But I can
> see it when trying to load from spatialite_gis but that throws the same
> error.
> I noticed in the DB Manager plugin, it says that pyspatialite is missing
> and that package isn't available for openSUSE in the open build service,
> unless it goes by a different name...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121209/4c1f38ca/attachment.html>
