[Qgis-user] Cannot add sqlite/spatialite layers to qgis (they come in as tables)
Alex Mandel
tech_dev at wildintellect.com
Sun Dec 9 13:28:44 PST 2012
Yes, work in the master is going on to update the provider. I'm not sure
if you can backport that. Since there are likely no more releases in the
QGIS 1 series you might have to wait for QGIS 2 to get spatialite 4 support.
There's info on the qgis-dev list about this.
Thanks,
Alex
On 12/09/2012 12:43 PM, Angelos Tzotsos wrote:
> Hi Donovan,
> Yes, we upgraded spatialite to 4.0 a few days ago.
> I will talk with other maintainers on how to solve this issue. Having 2
> versions of spatialite will probably make things worse, since many
> libraries compile against it. We would need to make a selection I am
> afraid.
> I am wondering if there is a patch solving this issue or if this is
> solved in git master.
> Any ideas?
> Angelos
> On 12/09/2012 10:28 PM, Donovan Cameron wrote:
>> Thanks Andre, I found that in the midterm already =) and it works great.
>> I was trying to use the Layer > Create option, but I couldn't actually
>> make
>> a valid layer, I could only use that to create the sqlite database. It
>> wouldn't let me put any layers into it.
>> *"From the layer menu in QGIS, I can't create a layer in a sqlite db. It
>> says that my layer is invalid and can't be created. Then I can't even see
>> this sqlite database (that got created successfully, it's just the layer
>> that failed creation) when navigating from the add vector window. But
>> I can
>> see it when trying to load from spatialite_gis but that throws the same
>> error."
>> *This is probably because qgis uses the latest spatialite I have
>> installed
>> to make the new layer in the sqlite db.
>> I've filed this bug to see if they can consider building a spatialite v3
>> package in the meantime for RPM based linux distros.
>> https://bugzilla.novell.com/show_bug.cgi?id=793570
>> On Sun, Dec 9, 2012 at 1:19 PM, Andre Joost
>> <andre+joost at nurfuerspam.de>wrote:
>>> Am 09.12.2012 20:16, schrieb Alex Mandel:
>>> The plugin requires pyspatialite but QGIS itself has the provider
>>> built
>>>> in.
>>>> "SpatiaLite version ..: 4.0.0"
>>>> Grab an older version of the Spatialite GUI (1.4 or 1.5) or figure out
>>>> how to convert your db to the 3.x variant (I believe the release notes
>>>> mention this is possible).
>>> There is a spatialite_convert tool that converts 3.x databases to 4.x
>>> and
>>> back. See
>>> https://www.gaia-gis.it/**fossil/libspatialite/wiki?**
>>> name=switching-to-4.0<https://www.gaia-gis.it/fossil/libspatialite/wiki?name=switching-to-4.0>
>>> I usually create sqlite databases with Layer->Create new spatialite
>>> layer,
>>> and entering a new filename. The gui can read 3.x and 4.x databases
>>> wkithout problem.
>>> HTH,
>>> André Joost
>>> ______________________________**_________________
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
