[Qgis-user] How to display WMS legend (getLegendGraphic-request) in QGIS
Diego Mo diego.mo at csi.it
Tue Dec 11 09:08:35 PST 2012
Hello Astrid
if you can update the plugin from the same repository, it should now work also
with WMS exposed via https (the one you reported it works for me)
best regards
Diego Mo
CSI-Piemonte
Direzione Territorio e Ambiente
 >  _________________________________________________________________________
 >  Il 10 dicembre 2012 alle 11.14 Astrid Emde <astrid.emde at wheregroup.com> ha
 > scritto:
>  Hello Diego,
>   >   we tested the new CSI WMS Legend plugin a bit more and noticed that it
>   > does not support https-Requests for WMS.
>   >   Is support for https-requests not implemented yet?
>   >   Here is a demo WMS with an https-address.
>   >  https://lx-gis.stadt.wolfsburg.de/cgi-bin/mapserv?map=/gds/map/stadtteilgrenzen_extern.map&VERSION=1.1.1
>   > <https://lx-gis.stadt.wolfsburg.de/cgi-bin/mapserv?map=/gds/map/stadtteilgrenzen_extern.map&VERSION=1.1.1>
>   >   Best regards Astrid Emde
>   >   Am 07.12.2012 14:17, schrieb Astrid Emde:
>      > >      Hello Diego,
> >       >   thanks for the information. I tried the plugin and it is what I am
> >       > looking for.
> >       >   It shows the legend of the layer that has the focus in the
> >       > layertree. Nice.
> >       >   Thanks for your help.
> >       >   Astrid
> >       >   Am 07.12.2012 13:16, schrieb Diego Mo:
> >          > > >          Recently we build a little QGIS plugin to display
> >          > > > WMS legends.
> > >          It work with QGIS 1.8, not yet with the nightly build.
> > >           >   We are going to release this plugin on the official repo.
> > >           >   At the moment, if you want test it, you can download it from
> > >           > this repo: http://osgis.csi.it/qgis_plugin/csi_plugin_test.htm
> > >           > <http://osgis.csi.it/qgis_plugin/csi_plugin_test.htm>
> > >           > (remember to set "Show all plugin, even those marked as
> > >           > experimental" in the python plugin option panel)
> > >           >   Thanks in advance for every feed back
> > >           >   Best regards
> > >           >   Diego Mo
> > >           >   CSI-Piemonte
> > >           >  Il 7 dicembre 2012 alle 9.28 Astrid Emde
> > >           > <mailto:astrid.emde at wheregroup.com> ha scritto:
> > >           >  > Am 07.12.2012 09:12, schrieb Jürgen E. Fischer:
> > >           >  > > Hi Astrid,
> > >           >  > > On Fri, 07. Dec 2012 at 09:51:57 +0100, Astrid Emde
> > >           >  > > wrote:
> > >           >  > >> I am using WMS in QGIS and would like to diplay the
> > >           >  > >> legend from the
> > >           >  > >> getLegendGraphic-request in my application.
> > >           >  > >> Is there a possibility to do this?
> > >           >  > > I think there's no client support for that yet. The
> > >           >  > > server has support for
> > >           >  > > that and the webclient uses it, but the legend for the
> > >           >  > > WMS.
> > >           >  > > We could probably replace the "standard" raster legend
> > >           >  > > item with the
> > >           >  > > getlegendgraphcis response.
> > >           >  > > Jürgen
> > >           >  > Hello Jürgen,
> > >           >  > thanks for your reply.
> > >           >  > The Solution to use the getlegendgraphcis response if it
> > >           >  > exists sounds
> > >           >  > good to me. Maybe it could be displayed in a separate frame
> > >           >  > in QGIS.
> > >           >  > I am using QGIS 1.8-0
> > >           >  > Mit freundlichen Grüßen
> > >           >  > Astrid Emde
> > >           >  > Where2B Konferenz 2012
> > >           >  > 13. Dezember 2012 in Bonn
> > >           >  > www.where2b-conference.com
> > >           >  > <http://www.where2b-conference.com>
> > >           >  > Astrid Emde
> > >           >  > WhereGroup GmbH & Co.KG
> > >           >  > Eifelstraße 7
> > >           >  > 53119 Bonn
> > >           >  > Germany
> > >           >  > Fon: +49(0)228 90 90 38 - 19
> > >           >  > Fax: +49(0)228 90 90 38 - 11
> > >           >  > www.wheregroup.com <http://www.wheregroup.com>
> > >           >  > Folgen Sie der WhereGroup auf twitter:
> > >           >  > http://twitter.com/WhereGroup_com
> > >           >  > <http://twitter.com/WhereGroup_com>
> > >           >  > Amtsgericht Bonn, HRA 6788
> > >           >  > Komplementärin:
> > >           >  > WhereGroup Verwaltungs GmbH
> > >           >  > vertreten durch:
> > >           >  > Olaf Knopp, Peter Stamm
> > >           >  > pgp-public key:
> > >           >  > http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
> > >           >  > <http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284>
> > >           >  > Signierte und/oder verschlüsselte Nachrichten sind sehr
> > >           >  > willkommen
> > >           >  > Signed and/or encrypted mail is highly appreciated
> > >           >  > Qgis-user mailing list
> > >           >  > Qgis-user at lists.osgeo.org
> > >           >  > <mailto:Qgis-user at lists.osgeo.org>
> > >           >  > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > >           >  > <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> > >          Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> >      Astrid Emde
> >      www.where2b-conference.com <http://www.where2b-conference.com>
> >       Astrid Emde
> >       Eifelstraße 7
> >       53119 Bonn
> >       Germany
> >       astrid.emde at wheregroup.com <mailto:astrid.emde at wheregroup.com>
> > http://twitter.com/WhereGroup_com <http://twitter.com/WhereGroup_com>
> >      Komplementärin:
> >      vertreten durch:
> >       pgp-public key:
> >        Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>  Astrid Emde
>   Astrid Emde
>   Eifelstraße 7
>   53119 Bonn
>   Germany
>   Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
>  Komplementärin:
>  vertreten durch:
>   pgp-public key:
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121211/6257c600/attachment.html>
