[Qgis-user] help
Els Dens
els.dens at vlaamsbrabant.be
Fri Dec 21 00:48:55 PST 2012
Unsubscribe please,
Thank you
Els Dens - GIS-projectleider
Directie Informatica - Dienst projecten en ontwikkelingen
Provincie Vlaams-Brabant mail: els.dens at vlaamsbrabant.be
Provincieplein 1 tel : 016/26 79 18
B-3010 Leuven fax : 016/26 79 08
-----Oorspronkelijk bericht-----
Van: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Namens qgis-user-request at lists.osgeo.org
Verzonden: vrijdag 21 december 2012 1:23
Aan: qgis-user at lists.osgeo.org
Onderwerp: Qgis-user Digest, Vol 82, Issue 49
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of Qgis-user digest..."
Today's Topics:
1. Problem with pyspatialite (Pedro Ven?ncio)
2. Re: Problem with pyspatialite (Pedro Ven?ncio)
Message: 1
Date: Thu, 20 Dec 2012 13:52:59 -0800 (PST)
From: Pedro Ven?ncio <pedrongvenancio at yahoo.com>
To: Qgis Developer List <qgis-developer at lists.osgeo.org>,
"qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Problem with pyspatialite
Message-ID:
<1356040379.25059.YahooMailNeo at web122303.mail.ne1.yahoo.com>
Content-Type: text/plain; charset=utf-8
I was using QGIS master from nightly repository and it had been working well.
Today I have been compiling the version from github and I have a problem with pyspatialite. It was installed before, but now it does not appear in the repositories (Xubuntu 12.04).
Here is the error that appears when installing the compiled version:
dpkg: problemas com depend?ncias impedem a configura??o de python-qgis:
?python-qgis depende de python-pyspatialite; no entanto:
? O pacote python-pyspatialite n?o est? instalado.
dpkg: erro ao processar python-qgis (--install):
?problemas com depend?ncias - a deixar por configurar A instalar python-qgis-common (1.9.0) ...
ldconfig deferred processing now taking place Foram encontrados erros enquanto processava:
?python-qgis
python-qgis appears as "Broken" on Synaptic.
When I start QGIS, some plugins complain about the lack of pyspatialite:
ImportError: No module named pyspatialite
I've also tried to install pyspatialite with pip and easy_install, but without success.
sudo pip install pyspatialite
Downloading/unpacking pyspatialite
? Running setup.py egg_info for package pyspatialite Installing collected packages: pyspatialite ? Running setup.py install for pyspatialite ??? gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/usr/include/python2.7 -c /tmp/iconvb2Ux5M.c -o tmp/iconvb2Ux5M.o ??? /tmp/iconvb2Ux5M.c:1:1: warning: return type defaults to ?int? [-Wreturn-type] ??? /tmp/iconvb2Ux5M.c: In function ?main?:
??? /tmp/iconvb2Ux5M.c:2:5: warning: implicit declaration of function ?iconv? [-Wimplicit-function-declaration] ??? /tmp/iconvb2Ux5M.c:3:1: warning: control reaches end of non-void function [-Wreturn-type] ??? gcc -pthread tmp/iconvb2Ux5M.o -o a.out ??? building 'pyspatialite._spatialite' extension ??? gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -DMODULE_NAME="spatialite.dbapi2" -DVERSION="3.0.1" -DSQLITE_ENABLE_FTS3=1 -DSQLITE_ENABLE_RTREE=1 -DSQLITE_ENABLE_COLUMN_METADATA=1 -DOMIT_FREEXL=1 -I/Library/Frameworks/GEOS.framework/unix/include/ -I/Library/Frameworks/PROJ.framework/unix/include/ -Iamalgamation -I/usr/include/python2.7 -c src/module.c -o build/temp.linux-i686-2.7/src/module.o
??? In file included from src/module.c:24:0:
??? src/connection.h:36:5: error: conflicting types for ?spatialite_init?
??? /usr/include/spatialite.h:92:29: note: previous declaration of ?spatialite_init? was here ??? error: command 'gcc' failed with exit status 1 ??? Complete output from command /usr/bin/python -c "import setuptools;__file__='/home/pedro/build/pyspatialite/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --single-version-externally-managed --record /tmp/pip-MO3kIB-record/install-record.txt:
??? running install
running build
running build_py
running build_ext
/tmp/iconvb2Ux5M.c:3:1: warning: control reaches end of non-void function [-Wreturn-type] gcc -pthread tmp/iconvb2Ux5M.o -o a.out building 'pyspatialite._spatialite' extension gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -DMODULE_NAME="spatialite.dbapi2" -DVERSION="3.0.1" -DSQLITE_ENABLE_FTS3=1 -DSQLITE_ENABLE_RTREE=1 -DSQLITE_ENABLE_COLUMN_METADATA=1 -DOMIT_FREEXL=1 -I/Library/Frameworks/GEOS.framework/unix/include/ -I/Library/Frameworks/PROJ.framework/unix/include/ -Iamalgamation -I/usr/include/python2.7 -c src/module.c -o build/temp.linux-i686-2.7/src/module.o
Command /usr/bin/python -c "import setuptools;__file__='/home/pedro/build/pyspatialite/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --single-version-externally-managed --record /tmp/pip-MO3kIB-record/install-record.txt failed with error code 1 Storing complete log in /home/pedro/.pip/pip.log
sudo easy_install pyspatialite
Searching for pyspatialite
Reading http://pypi.python.org/simple/pyspatialite/
Reading http://pyspatialite.googlecode.com/
Reading http://code.google.com/p/pyspatialite/downloads/list
Best match: pyspatialite 3.0.1
Downloading http://pypi.python.org/packages/source/p/pyspatialite/pyspatialite-3.0.1.tar.gz#md5=28a6ab34b5003772e9468f2712100586
Processing pyspatialite-3.0.1.tar.gz
Running pyspatialite-3.0.1/setup.py -q bdist_egg --dist-dir /tmp/easy_install-zfgdJp/pyspatialite-3.0.1/egg-dist-tmp-enV8r4
Downloading amalgation.
? File "/usr/bin/easy_install", line 9, in <module> ??? load_entry_point('distribute==0.6.24dev-r0', 'console_scripts', 'easy_install')() ? File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 1931, in main ??? with_ei_usage(lambda:
? File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 1912, in with_ei_usage ??? return f() ? File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 1935, in <lambda> ??? distclass=DistributionWithoutHelpCommands, **kw ? File "/usr/lib/python2.7/distutils/core.py", line 152, in setup ??? dist.run_commands() ? File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands ??? self.run_command(cmd) ? File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command ??? cmd_obj.run() ? File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 368, in run ??? self.easy_install(spec, not self.no_deps) ? File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 608, in easy_install ??? return self.install_item(spec, dist.location, tmpdir, deps) ? File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 638, in install_item ??? dists = self.install_eggs(spec, download, tmpdir) ? File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 828, in install_eggs ??? return self.build_and_install(setup_script, setup_base) ? File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 1105, in build_and_install ??? self.run_setup(setup_script, setup_base, args) ? File "/usr/lib/python2.7/dist-packages/setuptools/command/easy_install.py", line 1094, in run_setup ??? run_setup(setup_script, args) ? File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 30, in run_setup ??? lambda: execfile( ? File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 72, in run ??? return func() ? File "/usr/lib/python2.7/dist-packages/setuptools/sandbox.py", line 32, in <lambda> ??? {'__file__':setup_script, '__name__':'__main__'} ? File "setup.py", line 219, in <module> ? File "setup.py", line 216, in main ? File "/usr/lib/python2.7/distutils/core.py", line 152, in setup ??? dist.run_commands() ? File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands ??? self.run_command(cmd) ? File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command ??? cmd_obj.run() ? File "/usr/lib/python2.7/dist-packages/setuptools/command/bdist_egg.py", line 179, in run ??? cmd = self.call_command('install_lib', warn_dir=0) ? File "/usr/lib/python2.7/dist-packages/setuptools/command/bdist_egg.py", line 166, in call_command ??? self.run_command(cmdname) ? File "/usr/lib/python2.7/distutils/cmd.py", line 326, in run_command ??? self.distribution.run_command(command)
? File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command ??? cmd_obj.run() ? File "/usr/lib/python2.7/dist-packages/setuptools/command/install_lib.py", line 20, in run ??? self.build() ? File "/usr/lib/python2.7/distutils/command/install_lib.py", line 111, in build ??? self.run_command('build_ext') ? File "/usr/lib/python2.7/distutils/cmd.py", line 326, in run_command ??? self.distribution.run_command(command)
? File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command ??? cmd_obj.run() ? File "/usr/lib/python2.7/distutils/command/build_ext.py", line 339, in run ??? self.build_extensions() ? File "/usr/lib/python2.7/distutils/command/build_ext.py", line 448, in build_extensions ??? self.build_extension(ext) ? File "setup.py", line 116, in build_extension ? File "setup.py", line 97, in get_amalgamation
IndexError: list index out of range
Has anyone encountered this problem? How can it be solved?
Message: 2
Date: Thu, 20 Dec 2012 16:23:08 -0800 (PST)
Subject: Re: [Qgis-user] Problem with pyspatialite
Message-ID:
<1356049388.50166.YahooMailNeo at web122303.mail.ne1.yahoo.com>
I solved installing python-pyspatialite from
http://pkgs.org/debian-wheezy/debian-main-i386/python-pyspatialite_3.0.1-2_i386.deb/download/?
Thanks,
Pedro
----- Original Message -----
?python-qgis
??? running install
running build
running build_py
running build_ext
Qgis-user at lists.osgeo.org
End of Qgis-user Digest, Vol 82, Issue 49
Aan dit bericht kunnen geen rechten worden ontleend. Alle berichten naar dit
professioneel e-mailadres kunnen door de werkgever gelezen worden. In het kader
van de vervulling van onze taak van openbaar belang nemen wij uw relevante
persoonlijke gegevens op in onze bestanden. U kunt deze inzien en verbeteren
conform de Wet Verwerking Persoonsgegevens van 8 december 1992.
Het ondernemingsnummer van het provinciebestuur is 0253.973.219
