[Qgis-user] QGIS and WMS
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Thu Dec 27 04:28:17 PST 2012
I've set up a GeoServer WMS on a networked server that my local QGIS
(1.8.0) is able to access.
I've noticed two issues:
(a) When making a request "Getting map via WMS"; QGIS locks up and uses
100% of a CPU core. But at this point shouldn't it not be doing anything
apart from waiting? Its only when the map is downloaded that QGIS becomes
responsive and CPU usage drops to nothing again.
(b) I use the mouse wheel to zoom in or out. I zoom muliple levels at once.
The problem is, QGIS seems to request every single intermediate level
between my starting and ending point even though once it has been
downloaded ("x of x bytes of map downloaded") it immediately starts
downloading the next and doesn't actually show the just-downloaded map.
Combined with (a) above this makes zooming using this method take a long
time.
Are these bugs I should be reporting on the tracker or designed behaviour?
Cheers,
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20121227/59412c4d/attachment.html>
