[Qgis-user] Create Garmin Custom Maps from QGIS as background maps for your GPS
SBL Stefan.Blumentrath at nina.no
Tue Feb 7 06:56:26 PST 2012
Dear all
Today, the GarminCustomMap - plugin reached a beta-version status.
The plugin exports the current map-canvas into a
http://garmin.blogs.com/my_weblog/2009/11/garmin-makes-custom-maps-free-and-easy.html
GraminCustomMap-file (.kmz) , which can be used as a background map on
compatible Garmin GPS units. See:
http://support.garmin.com/support/searchSupport/case.faces?caseId={7aca6c60-ac37-11e0-d01c-000000000000}
It has been successfully tested on a Windows XP and a Ubuntu machine, but
further testing would be very much appreciated.
Hopefully, the first stable version will be released soon (after external
testing).
If you are running a QGIS version <1.8, add
http://plugins.qgis.org/plugins/plugins.xml
http://plugins.qgis.org/plugins/plugins.xml  to the 3rd-party repositories,
to get access to the plugin. It is still marked as experimental, so you
would have to check that experimental plugins are listed.
Cheers
Stefan
View this message in context: http://osgeo-org.1560.n6.nabble.com/Create-Garmin-Custom-Maps-from-QGIS-as-background-maps-for-your-GPS-tp4372763p4372763.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
