[Qgis-user] Can I open NetCDF files with QGIS?
    Etienne Tourigny
    etourigny.dev at gmail.com
    Thu Feb  9 05:48:30 PST 2012
You have a custom QGis version then? I don't see how this relates to
gdal... Any chance this modification could be integrated into qgis
trunk?
Etienne
On Wed, Feb 8, 2012 at 6:20 PM, Yves Jacolin (free) <yjacolin at free.fr> wrote:
> Etienne,
> I don't think so as my netcdf have several subdataset. I have a windows pop up
> which allow me to choose the subdataset.
> Y.
> Le mercredi 8 février 2012 20:55:20, Etienne Tourigny a écrit :
>> QGis can open a netcdf file which has only 1 variable (along with
>> supporting lat/lon or X/Y dimension variables).
>> Perhaps that is what works for you?
>> Etienne
>> On Wed, Feb 8, 2012 at 5:42 PM, Yves Jacolin (free) <yjacolin at free.fr>
> wrote:
>> > Hello,
>> > I successfully did it. But my email won't help you as I don't know why. I
>> > guess my gdal binaries from my company has something specific.
>> > Y.
>> > Le mercredi 8 février 2012 19:59:06, Etienne Tourigny a écrit :
>> >> It seems that QGis does not support GDAL raster "subdatasets", I get
>> >> this with netcdf and hdf4  files.
>> >> Try this:
>> >> gdal_translate -of vrt NETCDF:"Glb_20111001.nc":cf_DangerRisk
>> >> danger_risk.vrt qgis danger_risk.vrt
>> >> For more information on subdatasets see the GDAL netcdf driver page:
>> >> http://www.gdal.org/frmt_netcdf.html
>> >> It's a pity this doesn't work directly in QGis - anybody know if this
>> >> could be fixed/implemented?
>> >> It would be great to support subdatasets by adding a layer for each
>> >> subdataset, and perhaps even better with a dialog for selecting a
>> >> particular subdataset.
>> >> Regards,
>> >> Etienne
>> >> On Wed, Feb 8, 2012 at 3:51 PM, Paolo Corti <pcorti at gmail.com> wrote:
>> >> > Hi
>> >> > sorry if this has been discussed before, but according to what I see
>> >> > here [1] there was not an answer.
>> >> > I need to open a NetCDF file with QGIS.
>> >> > I am using QGIS 1.7.2, and GDAL 1.9.0.
>> >> > I can successfully manage NetCDF files with GDAL:
>> >> > $ gdalinfo --formats
>> >> > Supported Formats:
>> >> >  netCDF (rw+): Network Common Data Format
>> >> > $ gdalinfo Glb_20111001.nc
>> >> > Driver: netCDF/Network Common Data Format
>> >> > Files: Glb_20111001.nc
>> >> > Size is 512, 512
>> >> > Coordinate System is `'
>> >> > Metadata:
>> >> >  NC_GLOBAL#CDI=Climate Data Interface version 1.4.3
>> >> >  NC_GLOBAL#CDO=Climate Data Operators version 1.4.3
>> >> > (http://www.mpimet.mpg.de/cdo)
>> >> >  NC_GLOBAL#Conventions=CF-1.0
>> >> >  NC_GLOBAL#history=Wed Oct 12 23:30:47 2011: cdo -s -f nc merge
>> >> > af01_20111001.nc af02_20111001.nc pf01_20111001.nc pf02_20111001.nc
>> >> > pf03_20111001.nc pf04_20111001.nc pf05_20111001.nc pf06_20111001.nc
>> >> > pf07_20111001.nc pf08_20111001.nc pf09_20111001.nc pf10_20111001.nc
>> >> > pf11_20111001.nc pf12_20111001.nc pf13_20111001.nc pf14_20111001.nc
>> >> > pf15_20111001.nc pf16_20111001.nc pf17_20111001.nc pf18_20111001.nc
>> >> > pf19_20111001.nc pf20_20111001.nc pf21_20111001.nc pf22_20111001.nc
>> >> > pf23_20111001.nc pf24_20111001.nc pf25_20111001.nc pf26_20111001.nc
>> >> > pf27_20111001.nc pf28_20111001.nc pf29_20111001.nc pf30_20111001.nc
>> >> > pf31_20111001.nc pf32_20111001.nc pf33_20111001.nc pf34_20111001.nc
>> >> > pf35_20111001.nc pf36_20111001.nc pf37_20111001.nc pf38_20111001.nc
>> >> > pf39_20111001.nc pf40_20111001.nc pf41_20111001.nc pf42_20111001.nc
>> >> > pf43_20111001.nc pf44_20111001.nc pf45_20111001.nc pf46_20111001.nc
>> >> > pf47_20111001.nc pf48_20111001.nc pf49_20111001.nc pf50_20111001.nc
>> >> > Glb_20111001.nc
>> >> > Wed Oct 12 23:30:39 2011: cdo -s -f nc merge
>> >> > pf50_20111001_DangerRisk.nc pf50_20111001_FWI.nc pf50_20111001.nc
>> >> > Wed Oct 12 23:30:37 2011: cdo -s -f nc mergetime
>> >> > pf50_20111001_20111001_FWI.nc pf50_20111001_20111002_FWI.nc
>> >> > pf50_20111001_20111003_FWI.nc pf50_20111001_20111004_FWI.nc
>> >> > pf50_20111001_20111005_FWI.nc pf50_20111001_20111006_FWI.nc
>> >> > pf50_20111001_20111007_FWI.nc pf50_20111001_20111008_FWI.nc
>> >> > pf50_20111001_20111009_FWI.nc pf50_20111001_20111010_FWI.nc
>> >> > Wed Oct 12 23:30:36 2011: cdo -s -f nc -R chname,var228,pf50_FWI -copy
>> >> > Work0/20111001_fwi/pf50/20111001_20111010_FWI.grib
>> >> >  NC_GLOBAL#institution=European Centre for Medium-Range Weather
>> >> > Forecasts Subdatasets:
>> >> >  SUBDATASET_1_NAME=NETCDF:"Glb_20111001.nc":cf_DangerRisk
>> >> >  SUBDATASET_1_DESC=[10x640x1280] cf_DangerRisk (32-bit floating-point)
>> >> >  SUBDATASET_2_NAME=NETCDF:"Glb_20111001.nc":cf_FWI
>> >> >  SUBDATASET_2_DESC=[10x640x1280] cf_FWI (32-bit floating-point)
>> >> > [cut]
>> >> > When I try to open this dataset with QGIS, this is what I get:
>> >> > Cannot get GDAL raster band.
>> >> > In the console this is what has been logged:
>> >> > Warning: QgsRasterLayer::setDataProvider: Data provider is invalid.
>> >> > ERROR 10: Pointer 'hObject' is NULL in 'GDALGetMetadata'.
>> >> > Any ideas? Should I open a ticket?
>> >> > thanks
>> >> > P
>> >> > [1] http://www.osgeo.org/pipermail/qgis-user/2011-July/012949.html
>> >> > Paolo Corti
>> >> > Geospatial software developer
>> >> > web: http://www.paolocorti.net
>> >> > twitter: @capooti
>> >> > skype: capooti
>> >> > _______________________________________________
>> >> > Qgis-user mailing list
>> >> > Qgis-user at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Yves Jacolin
> Yves Jacolin
