[Qgis-user] postgis / PHP
    uk52rob
    uk52rob at yahoo.co.uk
    Thu Feb  9 08:27:36 PST 2012
Hi Yves,
I hadn't come across geophp.com before, so thanks for the link.
It still seems beyond what is required though, unless i'm just being naive.
All I was wanting to do was have a very simple PHP script to create new
records in my PostGIS schema, or update / delete records. The issue
obviously comes when I want to make sense of the stored X/Y point data.
Is there a basic script that can convert PostGIS spacial point data to
OSGB36 X/Y or WGS84 lat/long and back again?
Thanks
-----Original Message-----
Sent: 09 February 2012 16:12
To: qgis-user at lists.osgeo.org
Cc: uk52rob
Subject: Re: [Qgis-user] postgis / PHP
Le Jeudi 9 Février 2012 16:04:29 uk52rob a écrit :
> Does anyone know of a simple PHP script which can be used to connect
> to a postgis DB and load / update a point layer?
> I really need something that would decode the 'the_geom' field to X/Y
> values, then re-encode on update.
uk52rob,
I don't know if it can help you, but you can see GeoPHP
http://www.geophp.com/
Y.
Yves Jacolin
http://yjacolin.gloobe.org
