[Qgis-user] Transferiing a project from MapInfor to QGIS....Please help.....
Andreas Neumann
a.neumann at carto.net
Thu Feb 9 23:31:49 PST 2012
Hi Naomi,
I have a few recommendations:
* if possible use a newer QGIS version like QGIS 1.7.x - there is a lot
of activity in QGIS development and it usually helps to stay with the
current stable version. One day you may even want to try OSGeo4W and the
trunk version ;-)
* Why do you want to open layers with Python? Is it not enough to just
load a QGIS project file? Is there a specific reason why you want to
load the layer with Python? It is certainly possible, but there may be
simpler options.
* The other requirement: why do you want a separate menu for layers if
there is a layer tree already where you can right-click and zoom to the
layer extent? If you insist on such functionality: there is a plugin
called "Layers menu from project".
Again: your requirement should be possible to fulfill with python - but
I fail to understand the requirement properly? What do you gain if you
have a separate tree in the menu if you already have a layer tree in
QGIS? Is it worth the effort developing such functionality?
Andreas
On Thu, 9 Feb 2012 18:38:30 -0800 (PST), naomi jackson wrote:
> Hi I am new to Quantum GIS,
> The organization i work for wishes to introduce QGIS to the Pacific
> Island Countries(the fact that is an Open source).
> i would really appreciate your help/assistance.
> The project that i am working on is to migrate a Project that i have
> completed in MapInfo 10.0 using Map Basic 10.0 into QGIS.
> "Customised MapInfo Display Of Land Cover Of The Low Lying islands"
> I wish to display the same in QGIS.
> My PC has :
> · Windows XP(and so do the other users in the department to which i
> will need to install QGIS in their systems when i get it working)
> · Python 2.7
> · QGIS 1.6.0
> Is it possible
> * Automatically open a layer using python “considering Windows
> XP”(I see a lot of examples on linux and Unix)…If so can anyone
> please guide me thru some codes or sites for more clarification.
> * Write a program to create a dropdown menu in QGIS to select
> layers
> and it automatically zooms to the layer selected rather than using
> the
> layer control to select manually.(WINDOWS XP)
> I have a whole lot of questions I will begin with these two…..
> I appreciate your suggestions and hope to get positive responses..
> Can anyuone help me with python codes that will do the two points
> above...if possible.
> Thanks
> Naomi
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org [1]
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team [2]
> Links:
> [1] mailto:Qgis-community-team at lists.osgeo.org
> [2] http://lists.osgeo.org/mailman/listinfo/qgis-community-team
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
