[Qgis-user] Re: GML2/GML3 encoding in WPS input (WPS plugin 0.6.16)
Horst Düster
horst.duester at kappasys.ch
Fri Feb 10 06:45:28 PST 2012
The plugin uses the QGIS class QgsVectorFileWriter() based on the OGR
library to generate GML output. As I can see you dont have any options
to decide between GML2 and GML3.
Hope that helps ...
Regards
Horst
Dr. Horst Düster
Kappasys
Alte Bernstrasse 13
CH-4500 Solothurn
Tel.: +41 (0) 32 514 00 40
Mobil: +41 (0) 76 408 51 06
eMail: horst.duester at kappasys.ch
skype: horstduester
Twitter: moazagotl
Web: www.kappasys.ch
lat: N 47° 12' 06.408" lon: E 7° 32' 13.740"
Am 10.02.2012 15:34, schrieb Augusttown:
> Hi Horst,
> I know the plugin is not manipulating the data coming back from server, but
> my question is about the data (request) sent by the WPS plugin, why is it
> GML2 instead of GML3?
> Thanks,
> Yingqi
> On Fri, Feb 10, 2012 at 1:32 AM, Horst Düster [via OSGeo.org]<
> ml-node+s1560n4382758h10 at n6.nabble.com> wrote:
>> Im not sure what happend in your case. But the Plugin doesnt manipulate
>> incoming data. It only downloads the resultand features from the server
>> as it is and integrates them into QGIS.
>> Regards
>> Horst
>> Dr. Horst Düster
>> Kappasys
>> Alte Bernstrasse 13
>> CH-4500 Solothurn
>> eMail: [hidden email]<http://user/SendEmail.jtp?type=node&node=4382758&i=0>
>> skype: horstduester
>> Twitter: moazagotl
>> Am 10.02.2012 07:25, schrieb Augusttown:
>>> Hi folks,
>>> I am using the QGIS WPS plugin to consume one WPS process. One of the
>> input
>>> parameter type is defined as below in process description:
>>> <ComplexData>
>>> <Default>
>>> <Format>
>>> <MimeType>text/xml</MimeType>
>>> <Encoding>UTF-8</Encoding>
>>> <Schema>http://schemas.opengis.net/gml/3.1.1/base/gml.xsd</Schema>
>>> </Format>
>>> </Default>
>>> </ComplexData>
>>> So I selected one feature from a shapefile layer as input and execute
>> the
>>> process, and in the Execute request WPS plugin sends I captured
>> following
>>> GML as complexData
>>> <gml:featureMember>
>>> <ogr:qt_temp fid="F1">
>>> <ogr:geometryProperty>
>>> <gml:Point>
>>> <gml:coordinates>-13629600.1153,4547314.1181999967</gml:coordinates>
>>> </gml:Point>
>>> </ogr:geometryProperty>
>>> </ogr:qt_temp>
>>> </gml:featureMember>
>>> Obviously the input feature is encoded as GML2, so I wonder why the
>> input
>>> feature is encoded as GML2 instead of GML3? Is it a limitation of
>> QGIS/WPS
>>> plugin or did I miss anything.
>>> I do notice that WPS plugin can successfully parse GML3 for some other
>>> process that output GML3, so how I can configure it to make WPS client
>>> encode input features as GML3?
>>> Thanks
>>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/GML2-GML3-encoding-in-WPS-input-WPS-plugin-0-6-16-tp4382424p4382424.html
>>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>>> Qgis-user mailing list
>>> [hidden email]<http://user/SendEmail.jtp?type=node&node=4382758&i=1>
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> [hidden email]<http://user/SendEmail.jtp?type=node&node=4382758&i=2>
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.n6.nabble.com/GML2-GML3-encoding-in-WPS-input-WPS-plugin-0-6-16-tp4382424p4382758.html
>> To unsubscribe from GML2/GML3 encoding in WPS input (WPS plugin 0.6.16), click
>> here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4382424&code=YW5ha2ludGFuZ0BnbWFpbC5jb218NDM4MjQyNHwtMjY2NTI4OTUx>
>> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: http://osgeo-org.1560.n6.nabble.com/GML2-GML3-encoding-in-WPS-input-WPS-plugin-0-6-16-tp4382424p4383461.html
