[Qgis-user] Re: How can we change x, y spatial reference system units to lat,long format in qgis?
Zoltan osgeo at zktweb.f9.co.uk
Mon Feb 13 04:59:55 PST 2012
For Example
Export your shape file to SQLite, then add two columns to the table for
lat,long
Then run a script like this javascript from Chris Veness (modified by me to
run under Ruby using johnson), it's also available in Ruby and Python if you
search.
The script will output lat,long as a point array, call the function with
your grid refs
 lat,long=OSG2LL(Easting,Northing)
you can then insert this data into the SQlite columns you added or output it
as CSV text for import
You need to set these two variables (Line 14 in the script) in the script to
your local northing and easting 'true origin'
So for UK Ordnance Survey grid refs they are
N0 = -100000,
E0 = 400000;                 // northing & easting of true origin, metres
They will be different for where you are.
Heres the javascript
     /*  Convert latitude/longitude <=> OS National Grid Reference points
(c) Chris Veness 2005-2010   */
     * convert geodesic co-ordinates to OS grid reference
     var LL2OSG=function LatLongToOSGrid(p) {
     var lat = toRad(p[0]), lon = toRad(p[1]);
     var a = 6377563.396, b = 6356256.910;          // Airy 1830 major &
minor semi-axes
     var F0 = 0.9996012717;                         // NatGrid scale factor
on central meridian
     var lat0 = toRad(49), lon0 = toRad(-2);  // NatGrid true origin
     var N0 = -100000, E0 = 400000;                 // northing & easting of
true origin, metres
     var e2 = 1 - (b*b)/(a*a);                      // eccentricity squared
     var n = (a-b)/(a+b), n2 = n*n, n3 = n*n*n;
     var cosLat = Math.cos(lat), sinLat = Math.sin(lat);
     var nu = a*F0/Math.sqrt(1-e2*sinLat*sinLat);              // transverse
radius of curvature
     var rho = a*F0*(1-e2)/Math.pow(1-e2*sinLat*sinLat, 1.5);  // meridional
radius of curvature
     var eta2 = nu/rho-1;
     var Ma = (1 + n + (5/4)*n2 + (5/4)*n3) * (lat-lat0);
     var Mb = (3*n + 3*n*n + (21/8)*n3) * Math.sin(lat-lat0) *
Math.cos(lat+lat0);
     var Mc = ((15/8)*n2 + (15/8)*n3) * Math.sin(2*(lat-lat0)) *
Math.cos(2*(lat+lat0));
     var Md = (35/24)*n3 * Math.sin(3*(lat-lat0)) * Math.cos(3*(lat+lat0));
     var M = b * F0 * (Ma - Mb + Mc - Md);              // meridional arc
     var cos3lat = cosLat*cosLat*cosLat;
     var cos5lat = cos3lat*cosLat*cosLat;
     var tan2lat = Math.tan(lat)*Math.tan(lat);
     var tan4lat = tan2lat*tan2lat;
     var I = M + N0;
     var II = (nu/2)*sinLat*cosLat;
     var III = (nu/24)*sinLat*cos3lat*(5-tan2lat+9*eta2);
     var IIIA = (nu/720)*sinLat*cos5lat*(61-58*tan2lat+tan4lat);
     var IV = nu*cosLat;
     var V = (nu/6)*cos3lat*(nu/rho-tan2lat);
     var VI = (nu/120) * cos5lat * (5 - 18*tan2lat + tan4lat + 14*eta2 -
58*tan2lat*eta2);
     var dLon = lon-lon0;
     var dLon2 = dLon*dLon, dLon3 = dLon2*dLon, dLon4 = dLon3*dLon, dLon5 =
dLon4*dLon, dLon6 = dLon5*dLon;
     var N = I + II*dLon2 + III*dLon4 + IIIA*dLon6;
     var E = E0 + IV*dLon + V*dLon3 + VI*dLon5;
     return OSGNum2Let(E, N, 8);
     * convert OS grid reference to geodesic co-ordinates
     var OSG2LL=function OSGridToLatLong([grx,gry]) {
     //var gr = OSGLet2Num(gridRef);
     var E = grx, N = gry;
     var a = 6377563.396, b = 6356256.909;              // Airy 1830 major &
minor semi-axes
factor on central meridian
     var lat0 = 49*Math.PI/180, lon0 = -2*Math.PI/180;  // NatGrid true
origin
squared
     var lat=lat0, M=0;
     do {
     lat = (N-N0-M)/(a*F0) + lat;
Math.cos(lat+lat0);
     } while (N-N0-M >= 0.000001);  // ie until < 0.01mm
radius of curvature
radius of curvature
     var tanLat = Math.tan(lat);
     var tan2lat = tanLat*tanLat, tan4lat = tan2lat*tan2lat, tan6lat =
tan4lat*tan2lat;
     var secLat = 1/cosLat;
     var nu3 = nu*nu*nu, nu5 = nu3*nu*nu, nu7 = nu5*nu*nu;
     var VII = tanLat/(2*rho*nu);
     var VIII = tanLat/(24*rho*nu3)*(5+3*tan2lat+eta2-9*tan2lat*eta2);
     var IX = tanLat/(720*rho*nu5)*(61+90*tan2lat+45*tan4lat);
     var X = secLat/nu;
     var XI = secLat/(6*nu3)*(nu/rho+2*tan2lat);
     var XII = secLat/(120*nu5)*(5+28*tan2lat+24*tan4lat);
     var XIIA = secLat/(5040*nu7)*(61+662*tan2lat+1320*tan4lat+720*tan6lat);
     var dE = (E-E0), dE2 = dE*dE, dE3 = dE2*dE, dE4 = dE2*dE2, dE5 =
dE3*dE2, dE6 = dE4*dE2, dE7 = dE5*dE2;
     lat = lat - VII*dE2 + VIII*dE4 - IX*dE6;
     var lon = lon0 + X*dE - XI*dE3 + XII*dE5 - XIIA*dE7;
     return [toDeg(lat), toDeg(lon)];
     * convert standard grid reference ('SU387148') to fully numeric ref
([438700,114800])
     *   returned co-ordinates are in metres, centred on grid square for
conversion to lat/long
     *   note that northern-most grid squares will give 7-digit northings
     *   no error-checking is done on gridref (bad input will give bad
results or NaN)
     var OSGLet2Num=function gridrefLetToNum(gridref) {
     // get numeric values of letter references, mapping A->0, B->1, C->2,
etc:
     var l1 = gridref.toUpperCase().charCodeAt(0) - 'A'.charCodeAt(0);
     var l2 = gridref.toUpperCase().charCodeAt(1) - 'A'.charCodeAt(0);
     // shuffle down letters after 'I' since 'I' is not used in grid:
     if (l1 > 7) l1--;
     if (l2 > 7) l2--;
     // convert grid letters into 100km-square indexes from false origin
(grid square SV):
     var e = ((l1-2)%5)*5 + (l2%5);
     var n = (19-Math.floor(l1/5)*5) - Math.floor(l2/5);
     // skip grid letters to get numeric part of ref, stripping any spaces:
     gridref = gridref.slice(2).replace(/ /g,'');
     // append numeric part of references to grid index:
     e += gridref.slice(0, gridref.length/2);
     n += gridref.slice(gridref.length/2);
     // normalise to 1m grid, rounding up to centre of grid square:
     switch (gridref.length) {
     case 6: e += '50'; n += '50'; break;
     case 8: e += '5'; n += '5'; break;
     // 10-digit refs are already 1m
     return [e, n];
     * convert numeric grid reference (in metres) to standard-form grid ref
     var OSGNum2Let=function gridrefNumToLet([e, n, digits]) {
     // get the 100km-grid indices
     var e100k = Math.floor(e/100000), n100k = Math.floor(n/100000);
     if (e100k<0 || e100k>6 || n100k<0 || n100k>12) return '';
     // translate those into numeric equivalents of the grid letters
     var l1 = (19-n100k) - (19-n100k)%5 + Math.floor((e100k+10)/5);
     var l2 = (19-n100k)*5%25 + e100k%5;
     // compensate for skipped 'I' and build grid letter-pairs
     if (l1 > 7) l1++;
     if (l2 > 7) l2++;
     var letPair = String.fromCharCode(l1+'A'.charCodeAt(0),
l2+'A'.charCodeAt(0));
     // strip 100km-grid indices from easting & northing, and reduce
precision
     e = Math.floor((e%100000)/Math.pow(10,5-digits/2));
     n = Math.floor((n%100000)/Math.pow(10,5-digits/2));
     var gridRef = letPair + e.padLZ(digits/2) + n.padLZ(digits/2);
     return gridRef;
     * extend Number object with methods for converting degrees/radians
     var toRad = function(d) {  // convert degrees to radians
     return d * Math.PI / 180;
     var toDeg = function(r) {  // convert radians to degrees (signed)
     return r * 180 / Math.PI;
     * pad a number with sufficient leading zeros to make it w chars wide
     Number.prototype.padLZ = function(w) {
     var n = this.toString();
     for (var i=0; i<w-n.length; i++) n = '0' + n;
     return n;
Is this the sort of thing you want to do?
You can also use 'gdal' from the command line to do the same thing I think
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-can-we-change-x-y-spatial-reference-system-units-to-lat-long-format-in-qgis-tp4382321p4464944.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
