[Qgis-user] Re: Mac OSX - ImportError: No module named gdal
    Giuseppe Sucameli
    brush.tyler at gmail.com
    Wed Feb 15 08:51:27 PST 2012
On Wed, Feb 15, 2012 at 5:32 PM, dpan <davepanitz at yahoo.com> wrote:
> Thanks William. So my existing path already included /usr/bin:
> /usr/bin:/usr/local/bin:/library/frameworks/GDAL.framework/Versions/1.8/Programs
AFAICS there's a /usr/local/bin in the path,
do you have 2 different python versions installed?
> In any case, I tried replacing my paths (per your suggestion) with:
> /Library/Frameworks/GDAL.framework/Programs:/usr/bin
> Producing error "env: python2.7: No such file or directory." Suspect the
> Versions/1.8 bit was important.
It confirm that python executable is in /usr/local/bin and not in /usr/bin.
That setting should be auto-generated for MacOS (unless you changed
it before).
Please, can you remove that string at all, then restart QGis and then
report here what's the path the GdalTools settings dialog displays?
> What seems strange to me is that it's able to find other modules, just not
> gdal_polygonize.
Are you sure? Does gdal_merge tool work?
Regards.
Giuseppe Sucameli
