[Qgis-user] Mac OSX - ImportError: No module named gdal
William Kyngesburye
woklist at kyngchaos.com
Wed Feb 15 17:02:06 PST 2012
> On Feb 15, 2012, at 12:06 PM, Giuseppe Sucameli wrote:
>> Hi,
>> On Wed, Feb 15, 2012 at 6:38 PM, dpan <davepanitz at yahoo.com> wrote:
>>> Per your advice I deleted the
>>> "Path to the GDAL binaries" setting and restarted qGIS, but now it's just
>>> blank - seems nothing was auto-generated.
>> because you're using an old version of GdalTools plugin, it was
>> updated in QGis master and also in the plugin repository.
>> The new version of GdalTools plugin allows you to set the path
>> to python modules (if not found like in your case).
>> Just use the Python Plugins Installer to update it (it could require to
>> enableexperimental plugins if not done before).
>> After installation, remove again the Path to executables in
>> Settings dialog, then restart. Now should be auto-filled.
>> If it doesn't still work, then set the Path to python modules to
>> something like
>> /Library/Frameworks/GDAL.framework/Versions/1.8/Python/2.7/site-packages
On Feb 15, 2012, at 12:45 PM, dpan wrote:
> Excellent - that worked! Thanks again.
> Dave
Well, even before the GdalTools plugin update, it should work with only the GDAL path I gave. The updates to the plugin were meant for an all-in-one QGIS, where external python programs don't know to look inside the QGIS app for modules.
>> Producing error "env: python2.7: No such file or directory." Suspect the
>> Versions/1.8 bit was important.
The real problem is that your GDAL install seems to be messed up. When installed, it changes the shebang at the top of all the GDAL python tools to use an explicit python version (2.6 for Snow Leopard and 2.7 for Lion) just in case a user has installed a different incompatible version of Python. Somehow your GDAL python tools got the wrong python version.
What does this return in a Terminal:
file /System/Library/Frameworks/Python.framework/Versions/2.7/Python
It should be "No such file or directory".
ls -l /Library/Frameworks/GDAL.framework/Versions
Forcing GdalTools plugin to use a user-installed Python 2.7 on Snow Leopard with the Python 2.7 version of the GDAL module may work, but I don't support that in my GDAL framework.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
