[Qgis-user] Announcing the release of QGIS 1.7.4
Ivan Mincik
ivan.mincik at gmail.com
Wed Feb 22 02:23:06 PST 2012
Hi Werner,
I switched my testing daily builds from 'release-1_7' branch to
'release-1_7_4' and since then, it is failing to build on Debian Squeeze
with following error:
[ 66%] Building CXX object
src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrass.cpp.o
cd /tmp/buildd/qgis-1.7.4/debian/build/src/providers/grass &&
/usr/bin/c++ -Dqgisgrass_EXPORTS -DQT_SVG_LIB -DQT_WEBKIT_LIB
-DQT_GUI_LIB -DQT_TEST_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_NETWORK_LIB
-DQT_CORE_LIB -DQT_NO_CAST_TO_ASCII -DQGISDEBUG=1 -DQT_DEBUG -g -O2 -g
-fPIC -I/usr/include/qt4 -I/usr/include/qt4/QtSvg
-I/usr/include/qt4/QtWebKit -I/usr/include/qt4/QtGui
-I/usr/include/qt4/QtTest -I/usr/include/qt4/QtXml
-I/usr/include/qt4/QtSql -I/usr/include/qt4/QtNetwork
-I/usr/include/qt4/QtCore -I/tmp/buildd/qgis-1.7.4/debian/build
-I/tmp/buildd/qgis-1.7.4/src/providers/grass/../../core
-I/tmp/buildd/qgis-1.7.4/src/providers/grass/../../core/raster
-I/usr/lib/grass64/include -I/usr/include/gdal -Wall -Wno-long-long
-Wformat-security -Wno-strict-aliasing -DCORE_EXPORT= -DGUI_EXPORT=
-DPYTHON_EXPORT= -DANALYSIS_EXPORT= -DGRASS_BASE=\"/usr/lib/grass64\"
-DGRASS_EXPORT= -o CMakeFiles/qgisgrass.dir/qgsgrass.cpp.o -c
/tmp/buildd/qgis-1.7.4/src/providers/grass/qgsgrass.cpp
/tmp/buildd/qgis-1.7.4/src/providers/grass/qgsgrass.cpp: In static
member function 'static QString QgsGrass::openMapset(QString, QString,
QString)':
/tmp/buildd/qgis-1.7.4/src/providers/grass/qgsgrass.cpp:468: error:
redeclaration of 'int pid'
/tmp/buildd/qgis-1.7.4/src/providers/grass/qgsgrass.cpp:456: error: 'int
pid' previously declared here
make[3]: ***
[src/providers/grass/CMakeFiles/qgisgrass.dir/qgsgrass.cpp.o] Error 1
make[3]: Leaving directory `/tmp/buildd/qgis-1.7.4/debian/build'
make[2]: *** [src/providers/grass/CMakeFiles/qgisgrass.dir/all] Error 2
make[2]: Leaving directory `/tmp/buildd/qgis-1.7.4/debian/build'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/tmp/buildd/qgis-1.7.4/debian/build'
make: *** [build-stamp] Error 2
Ivan Mincik
