[Qgis-user] Announcing the release of QGIS 1.7.4
Otto Dassau dassau at gbd-consult.de
Wed Feb 22 03:14:23 PST 2012
I have the same problem for SLES 11 with the package link provided from
Werner http://qgis.org/downloads/qgis-1.7.4.tar.bz2 based on release-1_7_4.
Should I try with release-1_7?
Regards
Otto
Am Wed, 22 Feb 2012 11:49:13 +0100
schrieb Jürgen E. Fischer <jef at norbit.de>:
> Hi Ivan,
> On Wed, 22. Feb 2012 at 11:23:06 +0100, Ivan Mincik wrote:
> > Hi Werner,
> > I switched my testing daily builds from 'release-1_7' branch to
> > 'release-1_7_4' and since then, it is failing to build on Debian Squeeze
> > with following error:
> Does you daily build pull?  The release branch should have the necessary
> fixed.
> BTW 1.7.4 for Squeeze is available at qgis.org
> Jürgen
