[Qgis-user] Google maps kml file won't open
Jake Maier j.m at jmforestry.com
Sat Feb 25 16:45:09 PST 2012
When I save Google Earth polygons or lines and look at the file, the first
point of the line or polygon has no coordinate and a phony projected
coordinate. Check if that is an issue for you. I don't know why that happens
on my system here, but a work around for me is to create a token first point
and delete it then with a program like garmin dnr (it's free) in case of
lines or in the case of polygons copy the last point into the space of the
first point.
I don't know if this is your issue, but again this happens regularly in my
system if I save GE layers.
Jake
-----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Alex Mandel
Sent: Saturday, February 25, 2012 7:36 PM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Google maps kml file won't open
On 02/25/2012 03:45 PM, Jel Coward wrote:
> Ubuntu 10.04
> QGIS 1.7.4
> kml file exported from google maps
> When I try opening with QGIS I get
>  The layer...../Pemberton Medical Clinic area2.kml is not a valid
> layer and can not be added to the map
> Any thoughts from the here gathered wise folks please?
> I am still a complete nube.....so please accept my apols if the there
> is something obvious that I should be doing that I am not doing :)
> Cheers
> jel
Often times if the kml is downloaded from Google Maps, it's not the actual
data but only a link to the real data which is hosted online.
An easy way to check is to open the kml in a text editor, it will be quite
short and obvious if the actual x,y data is in the file.
See http://sites.google.com/site/gmapstips/export-my-map-as-kml for more
information.
If this isn't the issue and the data is public and you can point us to a
copy to test that would be great.
Thanks,
Alex
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
