[Qgis-user] RE: joining ms access to shapefile
Koos Hagg
hagg.koos at gmail.com
Sat Feb 25 17:25:39 PST 2012
Hi Jake,
I have worked a bit with Access and QGIS together...from my experience
it works best when your database is saved in an older format (.mbd).
You can add the .mdb as an ODBC connection or (if I remember
correctly) the better way is to add it simply as a vector layer.
The only thing I don't like about it is that it is a static connection
(read only), but it works...
Koos
>Date: Sat, 25 Feb 2012 14:00:11 -0500
>From: "Jake Maier" <j.m at jmforestry.com>
>Subject: [Qgis-user] joining ms access to >shapefile
>To: <qgis-user at lists.osgeo.org>
>Hi I'm new to qgis (I have some ArcMap >experience) and I'm having problems
>joining a ms access database to a shapefile. I'm >using windows 7 and ms
>office 2007. I tried to google the information >about a join of access to
>shapefile but got more confused in the process >instead.
>Can anyone please help and give me some pointers.
>Thank you very much
>Jake
