[Qgis-user] Database Manager and service configuration
Andreas Neumann
a.neumann at carto.net
Mon Feb 27 00:27:33 PST 2012
Hi Giuseppe,
I can confirm that the connection works now much faster. It is now a
pleasure to work with.
I notice that the Preview of some (most?) views does not work. Is this
because the plugin does not know which column is the primary key? Should
I file a bug on this?
Thanks a lot for your work!
Andreas
On Sun, 26 Feb 2012 18:13:31 +0100, Giuseppe Sucameli wrote:
> Hi Andreas,
> On Sat, Feb 18, 2012 at 8:37 PM, Andreas Neumann
> <a.neumann at carto.net> wrote:
>> Let me know when I can test something.
> the first problem (slow connection) should be fixed [1], just use
> DBManager v0.1.17.
> I understand it was very annoying waiting for minutes before seeing
> something... I hope you can confirm it works now.
> I'm trying to fix also the other problem, the error displayed
> retrieving
> database privileges when a service is used to connect to the db.
> Regards.
> [1] http://hub.qgis.org/issues/5045
>> On 02/18/2012 04:51 PM, Giuseppe Sucameli wrote:
>>> Hi Andreas,
>>> On Thu, Feb 16, 2012 at 5:59 PM, Andreas Neumann
>>>> 1.
>>>> One issue I have is that opening db-manager takes 1-2 minutes (on
>>>> a
>>>> rather fast machine). Why is it taking so long to open the
>>>> connnection?
>>>> In main QGIS the connection opens quickly. My db has hundreds of
>>>> spatial
>>>> tables and views in about 50 schemas. Is it scanning all schemas
>>>> and
>>>> tables at the initial connection?
>>> I'm noticing the same, it's slow when the db has a lot of tables.
>>> I'm going deep inside the problem, I hope to fix it soon.
>>>> 2.
>>>> I get an error message after the connection:
>>>> Error:
>>>> database "an" does not exist
>>>> Query:
>>>> SELECT has_database_privilege('an', 'CREATE'),
>>>> has_database_privilege('an', 'TEMP')
>>>> Why is it looking for a database named after the user connecting
>>>> to the db?
>>> Because DBManager is trying to display information about the
>>> database
>>> (permissions), but you have no dbname as you're using a service to
>>> connect to it.
>>> Tickets opened for both the problems ([1] and [2]),
>>> Regards.
>>> [1] http://hub.qgis.org/issues/5044
>>> [2] http://hub.qgis.org/issues/5045
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
