[Qgis-user] Questions QGIS webclient
Andreas Neumann a.neumann at carto.net
Tue Feb 28 05:26:49 PST 2012
 On Tue, 28 Feb 2012 13:53:01 +0100,  wrote:
> Hallo Andreas,
> seems to be related with http://hub.qgis.org/issues/3959
> the proposed double \\ works
> this also worked for me:
> was: ... 'BOX\(|\)','','g'),' ',',')||']'::text AS bbox ...
> now: ... 'BOX[(]|[)]','','g'),' ',',')||']'::text AS bbox ...
> found the hint in the first user comment at
> http://www.postgresql.org/docs/8.4/interactive/functions-matching.html#FUNCTIONS-POSIX-REGEXP
 so it seems that this issue will go away once people are moving to
 PostgreSQL >=9.0
 Maybe we should just add a commented line for standard conforming vs.
 non-standard conforming PostgreSQL installations.
> standard_conforming_strings is not set in my postgresql.conf
> (PostgreSQL 8.4)
> as we are into wsgi there are more questions (I have no clue about
> wsgi, but did some QGIS-extensions in Python):
> 1) why do you use psycopg2 instead of QtSql (additional installation
> needed as PyQt4 is installed because of QGIS anyhow)?
 Because psycopg2 has fewer dependencies and leaner. The script may run
 on a different server where there is not qt installed. I agree that on
 QGIS desktop qtsql makes more sense, but I am not so sure about the
 server.
> 2) I got a runtime error because the try - except clauses in both
> scripts do continue even if the try is unsuccessful, e.g. the conn
> object is undefined if psycopg2.connect is unsuccessful. IMHO the
> rest
> of the code must go into the try block or the except block must
> return. What happens with the string errorText? Is it dumped in some
> logfile?
> 3) Documentation says the search table is supposed to have a field
> searchstring_tsvector (type tsvector) but it is not used, instead
> searchstring::tsvector is used!
> I experimented with tsvector; the WHERE clause in search.wsgi which
> reads
> "searchstring::tsvector @@ lower('"+querystrings[j]+":*')::tsquery"
> This works fine if you have a street name like 'Am alten Gaswerk':
> select 'Am alten Gaswerk'::tsvector  @@ 'Gaswerk'::tsquery returns
> true
> select 'Am alten Gaswerk'::tsvector  @@ 'Am'::tsquery returns true
> BUT
> select 'Karl-Marx-Allee'::tsvector  @@ 'Marx'::tsquery returns false
> select 'Karl-Marx-Allee'::tsvector  @@ 'Karl'::tsquery returns false
> PostgreSQL provides to_tsvector and to_tsquery functions
> select to_tsvector('Karl-Marx-Allee') @@ to_tsquery('Karl')
> select to_tsvector('Karl-Marx-Allee') @@ to_tsquery('Marx')
> both return true
> select to_tsvector('Am alten Gaswerk') @@ to_tsquery('Gaswerk')
> returns true
> BUT
> select to_tsvector('Am alten Gaswerk') @@ to_tsquery('Am') returns
> false :( because Am is skipped by to_tsvector
> EVEN WORSE
> select to_tsvector('german', 'Über den Teufelslöchern') returns
> 'teufelsloch':3, a user has to enter quite some characters before the
> query returns something and if he enters "Teufelslöcher" he won't get
> any result.
> So tsvector is fine for texts skipping all the fill words and
> reducing nouns to their single form but as we are dealing with place
> names we do not want this behaviour. We could use PostgreSQL's ILIKE
> but this would result in a full string comparison and I guess in a
> lower performance.
> My workaround was to use searchstring_tsvector and to use a different
> language for to_tsvector and to_tsquery:
> CREATE VIEW ... AS SELECT ... to_tsvector('spanish', stringfield) AS
> searchstring_tsvector ...
> and change search.wsgi accordingly:
> searchstring_tsvector @@
> to_tsquery(\'spanish\','"+querystrings[j]+":*')
> select to_tsvector('spanish', 'Über den TEufelslöchern') @@
> to_tsquery('spanish', 'Über') returns true
> I can create tickets (and provide patches) for these issues.
 yes - please provide patches if you have improvements here. I do not
 fully understand the whole tsvector and tsquery thing. We may want to
 experiment with ILIKE if it is fast enough for our purpose.
 Andreas
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
