[Qgis-user] qgis 1.7.4 and libgdal
Agustin Lobo
alobolistas at gmail.com
Tue Feb 28 08:02:08 PST 2012
Does qgis 1.7.4 (from binaries in ubuntugis-unstable for 10.04)
require libgdal1-1.8.0 and python-gdal 1.8.0 or can it work with
libgdal1 1.9 and python-gdal 1.9?
I keep on with the following dilemma:
1. If I install python-gdal 1.9 I get startup errors such as:
Couldn't load plugin openlayers due an error when calling its
classFactory() method
File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 138, in
startPlugin
plugins[packageName] = package.classFactory(iface)
File "/home/alobo/.qgis/python/plugins/openlayers/__init__.py", line
48, in classFactory
from openlayers_plugin import OpenlayersPlugin
File "/usr/lib/python2.6/dist-packages/qgis/utils.py", line 283, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "/home/alobo/.qgis/python/plugins/openlayers/openlayers_plugin.py",
line 35, in
from openlayers_ovwidget import OpenLayersOverviewWidget
File "/home/alobo/.qgis/python/plugins/openlayers/openlayers_ovwidget.py",
line 28, in
import bindogr
File "/home/alobo/.qgis/python/plugins/openlayers/bindogr.py", line 1, in
from osgeo import ogr, osr
File "/usr/lib/python2.6/dist-packages/osgeo/__init__.py", line 21, in
_gdal = swig_import_helper()
File "/usr/lib/python2.6/dist-packages/osgeo/__init__.py", line 17,
in swig_import_helper
_mod = imp.load_module('_gdal', fp, pathname, description)
ImportError: /usr/lib/python2.6/dist-packages/osgeo/_gdal.so: symbol
VSIFTruncateL, version GDAL_1.9 not defined in file libgdal.so.1 with
link time reference
2. If I use python-gdal 1.8.02, no startup problems but cannot use
gdal tools (within or outside qgis).
Agus
