[Qgis-user] QGIS 1.7.4 doesn't run in OpenSUSE 12.1
Sebastian Schubert schubert.seb at googlemail.com
Wed Feb 29 01:45:03 PST 2012
On 27/02/12 21:42, Sascha Eichenauer wrote:
> On 02/27/2012 09:38 AM, Donovan Cameron wrote:
>> When I try to run qgis from the terminal, the splash shows, but as soon as
>> it gets to the part "Starting Python" the splash simply closes.
>> The output from the terminal is:
>> *qgis: siplib.c:10938: sipEnumType_alloc: Assertion
>> `(((currentType)->td_flags & 0x0007) == 0x0003)' failed.*
>> *Aborted*
>> I downloaded and installed QGIS from the "geo" repository (
>> http://download.opensuse.org/repositories/Application:/Geo/openSUSE_12.1/)
>> QGIS: 1.7.4-Wroclaw
>> OS: OpenSUSE 12.1 with KDE 4.8
>> Kernel: 3.1.9-1.4-desktop
> the QGIS in the GEO: repository is built against Qt 4.7 which ships with
> KDE 4.7. KDE 4.8 comes with Qt 4.8. You either have to build QGIS from
> source or downgrade to KDE 4.7. That's why I did not upgrade to KDE 4.8...
I use KDE 4.8. I downloaded the srpm and built it myself. Fairly
straightforward. I had to install some additional dependencies for
building and had to comment some lines in the spec file about debugging
information (I guess the spec wants me to generate debugging symbols but
I don't know how and I was to lazy to investigate).
Sebastian
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120229/db2a2c8e/attachment.sig>
