[Qgis-user] how to georeferenced an autocad .dxf file?
Andreas Neumann a.neumann at carto.net
Wed Feb 29 02:00:43 PST 2012
 It would actually be very nice if the georeferencer tool in QGIS could
 also handle vector layers. I would assume that much of the code from the
 existing georeferencer could be re-used to also make vector
 georeferencing work.
 I think it is annoying that one cannot easily transform vector data
 usign a couple of match-points.
 Andreas
 On Wed, 29 Feb 2012 10:55:18 +0100,  wrote:
> On Wed, 29 Feb 2012 09:50:39 +0000, M.E.Dodd wrote:
>> I have a building and roads plan done in a cad package and want to
>> accurately georeference it and deal with it in qgis.  I can choose
>> fixed points on the .dxf file and get accurate gps readings for
>> these
>> points but am wondering how to do the conversion in qgis?  If it
>> were
>> a raster image then it would be a simple matter of georeferencing
>> the
>> image but I want to keep the vector format so that its possible to
>> edit and layer with other maps of the area.
> I do this kind of work directly in the CAD app where you can copy and
> paste to coordinate, then all the features are correctly
> georeferenced
> and I only have to deal with the import process and apply the
> corresponding projection.
> Qgis-user mailing list
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
